Question about Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop
Problems with getting bootable disks to be read - Dell/VISTA
Not sure whether there are two problems here or one - but help would be appreciated!
The problem started when I discovered that I had forgotten my Administrator Account Password - when I tried to adjust my son's time limit access to his PC (he was spending WAY too much time on it). I am the only one with Administrator access (dumb!). Tried all the tricks but couldn't recall the name. The OS is VISTA. Searched the web and decided to try OphCrack. Downloaded it and created (I think) an optical image disk on a CD (using Nero software, that came bundled with PC). I think the burning went OK - I have a single executable file (several MB) on the CD.
I then took the burned CD to the problem PC, loaded and rebooted it. No luck. Then rebooted, went to Set Up/Boot Menu and changed the Priority so that the DVD/CD drive (single drive on this PC) was read first - BEFORE the hard drive. Rebooted and got an error message.
Not sure how to interpret the following message:
SATA 0 - ST325082045 3.ADG
SATA 1 HL-DT-STDVD +-RW GSA H31
SATA 2
SATA 3
"diskette drive 0 seek failure"
I've also tried the It looks to me as though the DVD/CD drive is not being recognized. Normally, I'd figure that this means the DVD/CD drive is broken, but that doesn't make sense because my son continues to be able to play his games on the PC, using the same drive.
I even tried, in desperation, to rewrite the entire hard drive, putting in the Dell VISTA reinstallation disk (that came with the PC), but this isn't being read either
At this point, I am almost out of ideas. Is there something I've overlooked?
If not, should I bite the bullet and take the PC to a repair shop? Should I purchase an external (changing out an internal drive is beyond me) DVD/CD drive (with USB port), and see if the PC will boot up using that drive?
Thanks for your help!
    Master:
  • 413 Answers
Replace the CMOS battery, go into the BIOS and disable the 'Floppy Seek' function, reconnect the SETA drives and you should be good to go...
The battery has about a 3 yr life expectancy, so after being 'off' for an extended period, I suppose it scrambled the BIOS settings. Diskette Drive 0 usually refers to the floppy drive, and I'm guessing that there isn't one installed in that machine, mainly since you didn't mention one being installed...
Posted on Dec 26, 2008
    Novelist:
  • 151 Answers
Solution:
i) when you start your system press button(F8 or F10 or DEL) so that you can go into BIOS menu now     try explore BIOS menu and see whether
  a) SATA 0 - ST325082045 3.ADG
  b) SATA 1 HL-DT-STDVD +-RW GSA H31
   are just visbile(in sense, you can see them in  BIOS writen ), this will make sure system is able to        detect them, we will be assured that your a)HARD DISK b) DVD writer   are working perfectly ......
    if so without any hesitation format or reload system with  Windows Vista....
ii) if otherwise any one of them or both are not visible in your BIOS Menu like a)HARD DISK b)DVD        writer
   try to open your computer tower and locate cables that are going to ur DVD writer, HARD DISK
   and reseat them(just remove the cable and place them again), by this way we are making sure that    no loose connections are existing..............you can even try new cables .......
   now restart ur system and go in to BIOS menu and repeat the step (i) ....
   if you are enable to see any one or both
      a) SATA 0 - ST325082045 3.ADG ....................HARD DISK
      b) SATA 1 HL-DT-STDVD +-RW GSA H31................DVD WRITER
  then you are having problem with either HARD DISK OR DVD WRITER  and you have to buy them .....
 Thanking you
M. Sridhar
I want to install windows vista by dell to my laptop will it work?
You can if you have regular Windows Vista disk, do not use Dell installation cd. (borrow from a friend or ask in your local comp. store if they can make you a bootable copy)
Use Vista key from the sticker on the dell computer. Make sure after install you put all the Vista drivers for the Toshiba so everything works ok.
Dec 01, 2012 | Toshiba Satellite L305D-S5895 Notebook
I have a KBT Neo-V MS-7032 V 1.0 motherboard that has problems booting from newer CD/DVDs. Some older CDs will boot such as the XP Pro installation disk. However, my Acronis backup restore disk and my...
Hi
Whether a CD will boot or not really decided by th emotherboard, it is decided by the basic control program called BIOS. BIOS works in a simple way by, if set to boot from a CD or DVD, checks whether the disk is bootable and, if so, boots from it.
First ensure that the discs you are using are all bootable.
Bootable Backup Restore and Partition Manager disks only work if data partitions already exist on the hard drive.
Bootable operating system discs can boot whether there is any data or partitions on the hard drive or not.
Partition Manager software can be used inside windows, to create, delete, resize and copy existing partitions. In other words, install and run the program from your Windows desktop.
Look here for guidance on creating bootable CDs
http://www.whatsabyte.com/P1/create_cd.htm
I hope this helps.
Aug 26, 2011 | MSI K8T Neo-V (MS7032-020) Socket 754...
Hi all, I have been desperately searching for a solution on the net all day. My Dell Inspiron 1420 on Vista platform will not boot up as a result of accidentally switching off the power. Have tried the F8...
This will fix it.
1. RUN DISK DEFRAGMENT FROM WITHIN YOUR OPERATING SYSTEM OR DURING STARTUP 2. RUN FISK DISK COMMAND FROM MS DOS 3. RUN CHKDSK COMMAND FROM MS DOS 4. IF YOU CONTINUE TO EXPERIENCE PROBLEMS, PLEASE RETURN FOR MORE DIRECT HELP FROM ME.
Jan 22, 2011 | Dell Computers & Internet
I can't get pass system set up it says that I don't have a bootable drive
you have hard disk failure. if its a SATA HDD there's a possibility that the data cable is the problem. change it & try. while you are at it remove the power cable & replace that too. however best would be if you could remove the HDD & check whether it works on any other computer. that way you can be sure what the problem is. if it reads on another PC then its either the above cables or your SMPS
Dec 15, 2010 | Dell OptiPlex GX280 PC Desktop
I have lenovo y410 laptop with windows vista installed on it.i changed the os to windows xp ,everything is working fine but the MATSHITE DVD RAM UJ85js is not reading the content of the cd ,but this drive...
Can the "bad" CD-R be properly read on some other computer?
If not, then the disk itself is the problem.
Otherwise, changing from Vista to XP does _NOT_ produce the type of problems that you are reporting.
Mar 22, 2010 | Sony 8x Internal Blu-ray...
I was having problems with reinstalling vista
use recovery disk to restore vista. if ur pc had data take ur pc to experts.
Feb 07, 2010 | Dell Inspiron 1525 Laptop Jet Black
No boot sector on hard disk - No bootable devices - strike F1 to
AFAIK all XP disks were bootable so maybe check your bios options.
If they are correct and it still does not boot them goto bootdisk.com and download the floppy setup disks for XP. You could then set your laptop to boot from floppy and install xp from there.
Aug 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
I have a dell dx280 when I start the pc. I can see some simbols in the bios screen, after that I try to install windows xp and in the process appear a blue screen with error message about hardware problem....
First refix RAM memory . then try to install windows xp 5 times untill you can.
i also face same problem it is due to memory related so i refix RAM and try winxp install 3 times and i succeded.
Jul 16, 2009 | Dell Optiplex GX280 (99301) Motherboard
Computer crash
this is all happen to not properly shut down, if your read the problem from blue screen so we can identify it give you some instruction how to fix it. YOu know only one can repair this is a computer technician or expert.. but i think you don't have so maybe your the one going to do it, here's is a instruction: 1. Put a Bootable System Disk XP or Vista or etc. 2. Make a Bootable Disk run before the system comes up... 3. Follow the procedure which appear on the screen... then so on.
Jul 09, 2009 | Dell Inspiron 1000 Notebook
Open Questions:
Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop Logo
240 people viewed this question
Alun Cox
