Question about Olympus Stylus 700 / 700 Digital Camera
My memory card is write protected
I tried formatting my card but it didnt work coz all of my saved photos are locked.they cant be deleted.what will i do??
  • Rick Byrd
    Rick Byrd May 11, 2010
    your card isn't in the lock position is it ?
    are you trying to format thru camera , card reader or pc ?
  • 53 Answers
There should be a little swith on the side of the card. switch to the opposite and then try
Posted on Aug 27, 2009
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
When trying to clear out my camera... there is a black screen & it'll say this picture cannot be deleted when i try to delete. taking up space that i would like to use
Make sure the picture you can't remove isn't locked. When you're in review press menu and make sure that photo isn't set to locked (if so unlock and you should be able to delete it).
If that doesn't help, make sure you copy off all the images on the card you want, as the following instructions are intended to clear the entire card.
After you transfer all the images you want, you'll want to format the memory card. This can be done one of two ways. If you have the appropriate card reader on your PC, you can insert the card, find it in my computer. Then right click it and select format.
The easier way is to use your camera's format feature. I don't have that specific model, but it can usually either be found in menu, or by pressing the picture review button and then menu. Formatting the card should erase all the data on it and clear off the picture you don't want.
Please leave feedback if this was helpful. Thanks.
Apr 05, 2011 | Panasonic Lumix DMC-FX3 Digital Camera
I CANT READ,FORMAT OR DELETE ANY DATA FROM MY SANDISK 2GB MEMORY CARD. WHEN I TRYING TO DO THE ABOVE FUNCTIONS, IT SHOWS 'THE MEMORY CARD IS WRITE PROTECTED'. I CANT SAVE A PHOTO WHICH I TOOK FROM MY...
on the side of the card there is a little sliding button, its set to the wrong setting...
Try moving it up or down and try again... if that does not help let us know.
Oct 06, 2010 | SanDisk 2GB microSD Memory Card
Try using the setup disk that came with the unit. This may be the only way to access the drive. My experience with the cheaper Sandisk drives is that the failure rate seems rather high. You could also try downloading the newest drivers from the Sandisk site.
Oct 06, 2010 | Computers & Internet
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Put new lexar sdhc 4GB memory card in my canon sd550 and get card locked. moved tab to both positions but same error message. do i need to return this card?
see if their might be some photos or file saved that you may have edited on the card maybe Microsoft visual studio's photo shop save to hard drive. delete with photo software and format put in camera format again. if it works with computer and not with the camera not compatible try another card
Jul 04, 2010 | Lexar Professional High-Speed 2GB Secure...
Can not get disk write protection to go off so i can delete photo
The write protection is software controlled. An error in the header record of the media may prevent you from changing this value. Save all the photos onto your computer and try formatting the memory card with the camera. Do not format the card or delete photos in your computer using a card reader device as this may be how the error was introduced.
Oct 08, 2009 | Canon PowerShot A540 Digital Camera
Memory card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
Nov 10, 2008 | Nikon Coolpix L11 Digital Camera
you can see a tiny lock (kind of sliding button with the label ("lock") in memory card. Try it
-Saran
May 06, 2008 | Motorola Mobility ROKR E6 Smartphone
Olympus Stylus 700 / 700 Digital Camera Logo
44 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
