Question about West Bend 6220 Slide Thru 2-Slice Toaster
West bend 6220 slide thru toaster
This is the seconf toaster that we bought and the same problem has occured. Only one side is now toasting.What can be osne
  • Anonymous Mar 01, 2009
    same problem here........but also, the inner rack doesn't release the toast to drop down.
I contacted West Bend customer service, when my toaster had a problem, and they sent me a new toaster.
Posted on May 13, 2009
SOURCE:
I didn't get a manuel and the toast does not go
The Instruction Manual for your West Bend 78224 QuickServe Toaster is available here:
http://www.westbend.com/supportdata/L5670-QuikServeToaster-ALL.pdf
Uneven or ragged edges on your toast can catch on the toast rack and prevent it from siding through on to the serving tray. Trim off any ragged edges.
Thank you for using FixYa!
Sep 15, 2011 | West Bend 78224 Toaster Oven
Need a carafe replacement model #5813 for west bend coffe/expresso machine model #55108
If you need to find parts for your West Bend slow cooker, West Bend coffee maker, West Bend Blender, West Bend popcorn maker, West Bend breadmakers, West Bend rice cooker/steamer, West Bend griddles/skillets/grills, and West Bend toasters/ovens the best place to go is www.westbend.com.
Also checkout this tip as it will help you to find what you are looking for on the website.
West Bend Kitchen Appliances Parts and Manuals
heatman101
Jan 21, 2011 | West Bend 55108 Espresso/coffee Maker
I need a replacement lid for a West Bend #58030 urn. Where can I buy one?
heatman101
Jan 18, 2011 | West Bend 58030 Coffee Maker
West bend 72300 need new cord
heatman101
Jan 17, 2011 | West Bend 72122 Electric Skillet
I need the manual of west bend cat 41047
heatman101
Jan 11, 2011 | West Bend 41047 Bread & Dough Maker
Need a manual for my west bend slow cooker model 84323
heatman101
Jan 10, 2011 | West Bend 84323 Slow Cooker
Villaware mornin toaster 5555-11 When you put the
When you push the slide down on the side, there's a wire that it pushes down inside the toaster. If the wire gets bent down a bit, pushing the slide down doesn't push the wire down enough. The wire is like a teeter totter. When it gets pushed down, it closes the circuit which turns the toaster on. The reason why the slide doesn't stay down is without energy, the electromagnet doesn't get engaged. That's what keeps the slide down. You need to remove the 4 screws on the bottom, and the 2 screws that hold the legs on that also hold the side on with the slide. Once the side is off, take a pair of needle nose pliers and bend the wire up a bit that acts as the teeter totter.
Jan 03, 2010 | VillaWare Mickey Mornin' 5555-11 2-Slice...
Toast won't stay down when handle pushed down handle comes up immediately as if not plugged in. Plug definitely in. Used only 3 times.
take it back. sounds like the magnetic coil that holds the handle down when it is plugged in is not functioning.
Oct 04, 2009 | West Bend 6220 Slide Thru 2-Slice Toaster
Slide button won't push down
I have the same problem, if my toaster isn't plugged in. If it is plugged in, it should work.
May 02, 2009 | West Bend 6220 Slide Thru 2-Slice Toaster
West Bend 6220 Slide Thru 2-Slice Toaster Logo
421 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Irene Tulloch
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
