Question about Daewoo DTQ-27U4SC 27" TV
Ps3 to old tv
The tv has audio video in the front and the ps3 has 3 connections, this means one jack is left out, I have a splitter but I dont know what to do with it
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, old TVs have a video in and a single/mono audio in. The PS3 has a yellow video out and 2 audio out (red & white) L/R. The yellow should go to the video in of the TV while the red & white should go to an adapter whose single end goes to the audio in. The adapter would look something like the image below.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 26, 2008
How do you connect a ps3 to a Emerson 32" TV, with yellow, white, and red cords
your yellow is the video in, white audio left, red audio right.
Feb 25, 2018 | Emerson Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
I have a 5.1 speaker setup. i have a 5.1 sony dvd amp. a ps3 and a old toshiba tv. ( the one with the orange white red plug in the back. i wanna hook up 3 speakers for front and the subwofer. how do i do...
So, you don't want to use the TV speakers, right? Hook your PS3 audio output RCA jacks to the input on the amplifier and hook the PS3 video cabe to the yellow (orange) video input of the TV. Then hook your speakers to the front or rear outputs of the amp and the sub to the sub output of the amp. If you want to use your TV speakers, you can connect them to the front or back output of the amp for a 4.1 setup. OK?
Dec 09, 2010 | Toshiba Toahiba Satellite A60 A65 Series...
Elgato EyeTV (T5301LL/A) Video Capture: I have an old camcorder - with only a yellow video...
If you have just one Audio Out RCA jack then the camcorder only recorded in MONO, so all you would need to do is either plug the wire coming from your single Audio Out jack into the left or white input jack of your Capture Device which may have an option in the software program to set it to recieve audio in MONO, or you can buy a RCA Jack Splitter that goes from a single Female RCA jack on one end and 2 Male RCA Jacks on the other end. Then you take the end of the Splitter with 2 plugs and plug one of them into the White Jack and the other into the Red Jack on your Capture Device, and the other end with just one plug should plug into the cord coming from the Black Jack on your Camcorder.
May 16, 2010 | Apple Elgato EyeTV (T5301LL/A) Video...
I have no TV output!
This will only work with a dvd player, PS3, XBOX 360, and other gaming consoles
You need:
- 3 AV Splitters (2 Female 1 Male sides cord)
- 1 Double sided Video and Audio Cables (Red, white, yellow cables)
Connect your consoles Video and Audio cables to the female sides of the splitters, next attach the Video and audio cables you bought to the splitters as well.
Now plug in the video/audio cables you bought into your TV.
If you did this everything properly this should work.
Sorry if this didnt help you
Mar 25, 2010 | Pinnacle Dazzle Video Creator Platinum...
How do i hook up a PS3 through my denon avr1905?
ONCE YOU CONNECT THE OPTICAL CABLE AT THE DENON, YOU ALSO NEED TO CHECK THE AUDIO SETTING FOR THE INPUT USED AND MAKE SURE OPTICAL IS SELECTED AND LAST ONCE YOU SELECT THE SOURCE INPUT USED TO CONNECT THE PS3 TO THE DENON PRESS THE INPUT MODE BUTTON ON THE FRONT LEFT OF THE DENON UNTIL YOU SEE DISPLAYED THE WORD AUTO, THIS SHOULD GET YOU SOUND AS LOND AS THE PS3 IS OUTPUTING AUDIO OVER THE OPTICAL
Mar 01, 2009 | Denon AVR-1905 Receiver
How to hook up vcr and dvd together ?
|DVD| -> |VCR| -> |TV|
1. Connect your VCR to your TV. (Using Antena cable or RCA cables.)
2. From your DVD player, choose the AUDIO VIDEO OUT. Then, connect that to your VCR's LINE IN jacks.
(*)Your DVD player has 3 jacks coming out. Yellow-video, White- Audio Left and Red- Audio Right.
If you VCR does not have the RED jack. Go to a radio shack and tell on of the sales person taht you need to connect 2 RCA audio outs to 1 RCA audio in. (He/ She will give you a "2RCA Male to 1RCA Female" splitter)
3. Finally, play your DVD, put your VCR channel in TV and most important select the LINE channel in your VCR. (This channal may called as L1, Line,... etc)
You should be seeing the DVD in your TV now.
If you want to play the VCR, just put the casset and play.
Important- The VCR needs to be powered on in order to the DVD signals to go to the TV.
Cheers!!!!
Feb 27, 2009 | TruTech TT1620 DVD Recorder
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Daewoo DTQ-27U4SC 27" TV Logo
705 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
