Question about Acer Aspire 3680 Laptop
Aspire 3680 Won't Come Up
Hello. I see that you responded to my problem of my laptop needing to be turned off/on 3 times before it comes up. You said that "maybe your graphics card is stuffed up." What does that mean? And how would I attempt to determine if it is indeed stuffed up? If it is, how then would I unstuff it. Thanks.
Acer Aspire 3680 laptop keyboard walked over by cat - now will not let me type - have cursor but no letters appear
Shut down the laptop and remove the battery . Now allow 15 minutes and then replace the battery back to boot again. If the PC does not respond with the keys, it must be checked if the cat had soiled the key pad and there is a short within.
Oct 06, 2011 | Acer Aspire 3680 Laptop
Drivers needs
Follow the below procedures:
1.Go to www.acer.com,
2. Select your Country/Continent
3. Look at the top of the page and click "Service and Support"
4. Look by the left side of the page, and click "Driver download"
5. Under Product family, Select 'Notebook
6. Under Product line, select "Aspire"
7. Select your laptop model and a list of all your laptop's driver will come up.
All you need to do is "Download" and that would be all.
Good luck.
Oct 05, 2010 | Acer Aspire 3680 Laptop
Aspire 3600 pci modem
I assume you are referring to the PCIMCIA driver ?
CardReader Vista Download (3680)
CardReader XP Download (3680)
CardReader XP Download (3600)
Jun 01, 2010 | Acer Aspire 3680 Laptop
Wireless switch is broken on my acer aspire 3680.
No you need switch,if you use a tiny screw driver you can turn it on with that if its just the plastic peice thats broke.use the screw driver to slide the mechanisam
Oct 04, 2009 | Acer Aspire 3680 Laptop
Will not turn on
Try removing the battery and reinserting again. If that doesn't work then you will need to take it in to a service centre for them to fix.
You can find manuals, drivers and utilities here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Thanks
C
Mar 25, 2009 | Acer Aspire 3680 Laptop
Need Acer 3680 VISTA all driver
Below there is the download page for your laptop from Acer.
Acer Europe - Service & Support, Drivers & Utilities, Downloads
Download drivers on the Vista section in page.
Remember to rate the solution.
Thanks.
Feb 18, 2009 | Acer Aspire 3680 Laptop
Problem Bringing up Acer Aspire 3680
Hi i think the problem is with the battery or power supply.When you power up the laptop without the external keyboard and mouse everything is ok, yes?Check that the battery is charging properly and that the charger is doing its job.
Dec 24, 2008 | Acer Aspire 3680 Laptop
On board mouse is not responding
Press the Key Fn and hold and then press the key F7 one time and leave it free... that enable again your laptop mousepad
Nov 20, 2008 | Acer Aspire 3680 Laptop
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
