Question about IBM ThinkPad R51 Notebook
IBM Laptop is turning on but it is not sustaining in the power on modde for long
The laptop was fallen down from my bike and there after the system is not working. The set turns on but within few seconds it goes off. We are doubting certain ICs as told earlier.
In case they are available we may try repairing the power module.
Pl. help
Regds,
When i Plug my charger with my laptop the charging powers stables where it is. It does not increase at all but it decrease when i remove my charger.
Your DC connections is loose on the system board:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
Find your manual:
HMM will provide you instructions for troubleshooting, diagnostics, removal and replacement laptop hardware. All IBM HMMs are publicly available. You can find HMM for your laptop on the IBM website or you can follow the link below. All HMMs are in pdf format, so you can download them and use at your convenience. For hardware replacement instructions find "Removing and replacing a FRU" chapter.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-39298
Dec 06, 2010 | IBM ThinkPad R60 Notebook
Tip
IBM Laptop Battery Power Saving Tips
How to try to extend the battery life are much concerned by many laptop users. Utilizing some small skills and minimize unnecessary waste of battery during the using process can make you full use of your laptop battery power.
The engineers of IBM personal computer business division give vast laptop users some good suggestions here to ensure that you can maximum extend laptop battery utility time. Therefore, it will improve your work efficiency; let you enjoy mobile office work and entertainment pleasure without limits.
IBM batteries on sale :
IBM thinkpad t40 Battery £ 37.52
ibm thinkpad t41 battery US $ 41.24
ibm thinkpad r60 battery. US $ 71.27
IBM ThinkPad T60 Battery £ 38.51
* Turn down the brightness of the screen. At the same time, although IBM ThinkPad laptop keyboard is equipped with lights, ThinkLight, but in order to save power, it is better to turn on it when under darkness conditions.
* When not using the wireless receiver device, turn it off please.
* Some users like opening CD or DVD to play music anytime, the power of battery will flow away quietly along with the music playing. Suggest everybody turn on the music only under the situation that they do want to enjoy the music.
* When the battery during using process, try to fully charge and discharge the battery.
* Try to avoid using it under high temperature and low temperature, for example, when you enjoy sunshine on the beach, please don’t leave your laptop in the car to enjoy SAUNA.
* Use proper AC adapter for your ThinkPad laptop.
* Use the IBM ThinkPad battery Battery MaxiMiser management software you select the most suitable for the extension of the power program.
* Use the IBM ThinkPad battery management software – Battery MaxiMiser, select the power extension program which suitable for you.
* Setup the standby time of monitor, hard disk and system sleep time, because it is no need to let your laptop still running at full load when you are at non-working stage.
* Under the Intel SpeedStep technology effect situation, the processor based on the current load situation adjusts the speed automatically to save battery power overall.
In fact, the laptop battery is a spiritual guy, after got expert advices, please treat it properly, it will bring you to enjoy a better mobile life.
battery info via:
http://www.sales-battery.com
http://www.global-battery.co.uk
on Jun 04, 2010 | Computers & Internet
Automatically shut down of my lap top
try to turn off the laptop, then remove the cables and battery on the laptop. Then press and hold the power button for 5 seconds. Reinsert the cables and battery on the pc. Turn on the pc and play games. Check if your pc could sustain. If not, try to upgrade your memory on the laptop...
May 15, 2010 | Dell Inspiron 6000 Notebook
Ibm thinkpad laptop
first, remove any external device as well as the ac adapter and the battery. while the ac adapter and battery is out, press and hold the power button for about 15seconds. then reconnect any power source and turn on the system. if it still doesnt turn on, remove memory, expansion cards, hard drive and optical drive then turn on the system. if it's still not turning on, the motherboard is faulty. but if it do turned on, reconnect the removed components one by one so you will determine which component is causing the issue. hope it'll help. good day. =)
Jan 07, 2010 | IBM ThinkPad A21m 2628 Notebook
How to set the ibm pc to factory setting, whick key to press for that.
Hi !!
Thank you for choosing Fixya.com
You can follow the steps given below.
    On an IBM Laptop system
  1. Step 1 Back up your data before starting this process.
  2. Step 2 Turn off your computer. After the computer has completely shut down, turn the laptop on.
  3. Step 3 Press the "F1" button, or the blue Access IBM button if your laptop has that option.
  4. Step 4 Choose "Restore Factory Settings" from the Menu screen that opens on your computer.
  5. Step 5 Follow all onscreen instructions. When the process is complete, the laptop is restored to factory settings.
Hope this would help.
Thanks nd Regards
Anurag Shukla
Sep 11, 2009 | Microsoft Windows XP Professional With...
Battery indicator on even after turn off the laptop
Reset the battery.....remove battery from system...boot while your adapter is plugged on....shut down..reinstall the battery......
if this doesn't help..
go to Control Panel>>>>>>Power Options and view setting ..........what does the system do after being switched off options
keep me posted
Cheers
Nov 17, 2008 | IBM ThinkPad T40 2373 Notebook
Frozen
Hold down the power button for 5-7 seconds and it will shut the laptop off. If that doesnt work, remove the battery from the bottom of the laptop and disconnect the AC adapter.
Apr 24, 2008 | IBM ThinkPad T20 2647 Notebook
Will not turn on at all traced voltage (15v) to system board but no power when pushing the power button
This is a shot in the dark, but I had a similar problem with an IBM. Turn out the Laptop Cover Sensor was stuck in its pushed down position ( The system though the lid was closed, when it was not... ), which sent the system to sleep mode before it could Initialise or get to the CMOS screen.
Hope it helps...
Jan 11, 2008 | Toshiba Satellite 1415-S173 Notebook
MY IBM T43 fails to boot
Take out the hard drive and see if the laptop still shuts down. If it doesn't then your hard drive might be the issue. You can also try reseating your memory.
Dec 26, 2007 | IBM ThinkPad T43 Notebook
IBM ThinkPad R51 Notebook Logo
78 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
