Question about Jensen VM9510 Car DVD Player
Wanting to install a mp6212 cd player in my tool box at work
How much of amps or milliamps will i need for the 12 volt power supply? i was told about 5 amps will work
  • dconwell Dec 26, 2008
    i was wanting to instal in tool box at work. would a small 2 0r 3 amp power suppy work?
  • 15,935 Answers
For proper operation, you will need 12V.
Some vehicles wont start unless there aer 8V.
Minimally 8VDC, but 12V recommended for proper internal amplifier operation. Purchase a used PC Power supply, and wire directly to the hard drive power pug. Inverters are also available.
BTW Amps are a measure of AC Current, not DC. DC is measured in Volts.
An Electrical appliance rated to work on AC will not work with DC, and vice versa.
You will need an invertor of some type to change the signal and wavelength.
Posted on Dec 26, 2008
If I want to bring 12 volt down to 3 volt via
You need to know in advance exactly how much current will be used and not just the maximum.
Resistance = voltage / current, so if you want to drop 9 volts at 1 amp, you'd use a 9 ohm resistor, but if it uses only 1mA, 9,000 ohms will be necessary. Most voltage converters use regulators which are much more complex than a single resistor.
Aug 29, 2014 | Cars & Trucks
Can i hook it up to a 12 volt plug in my home?
I have been installing car audio for over 40 years.A small adapter like you use to charge a phone,Doe,s not have enough amps in it to run the deck (Properly) When you crank up the vollume, The deck will cut out, You Can buy a bigger 12 Volt power supply from radio shack or the source that will power it (Properly) It should be at least 3 amp output .
Oct 17, 2012 | Pioneer DEH-P4800MP CD Player
New battery went dead. pulled the fuses and checked for a short. Found the fuse that shows a short just don't know what it goes too
A voltmeter is NOT the correct tool to check for an "ignition-off draw". A voltmeter will show 12 volts if ANYTHING is operating.
There are some things that are SUPPOSED to keep operating when the vehicle is shut off. These include, but are not limited to:
> Powertrain Control Module keep-alive memory
> Radio preset memory
> Clock
> Security/ alarm system
> Remote control recievers (door locks, etc.)
What you need to know is how many AMPS are being drawn from the battery when the vehicle is shut off. This is done by using a shunt bar connected between the battery terminal and the battery cable connector.
Set the ammeter to the lowest setting (usually 2 or 5 amp scale) Connect the ammeter leads accross the shunt bar. Turn off all electrical accessories, ignition switch, etc. and wait for a minimum of 45 minutes for all of the computer systems to go into "sleep" mode. Then open the shunt bar and read the amperage.
The "rule of thumb" is 300 milliamps (or 0.3 amps). This is where you have a problem. Anything less than this is not a problem and is not the cause of your dead battery. My experience is that most vehicles built in the last 15 years or so, will usually measure around 150 milliamps if there is no aftermarket equipment installed. Please note that even this 150 milliamps will measure as 12 volts if measured with a volt meter. A 2 amp draw will also measure as 12 volts....However, a 2 amp draw will kill your battery overnight and the 150 milliamp draw won't.
May 22, 2012 | 1999 Jeep Cherokee
Need to know the power reqierment's for boston digital BA735 model speaker set up. voltage plus MAh -AMp range?
12 volts AC, 1500-2000 milliamps, or 1.5-2 amps found here:
May 05, 2011 | Audio Players & Recorders
Lost power supply and the box doesnt state the voltage or amp requirement.
The power supply is 12 Volt, the center pin is +. i'm currently using a 1 amp replacement power supply(as the origional one burned out years ago), so anything > 1 amp @12 volts will work
Sep 21, 2010 | V-Stream Xpert 1280x1024 LCD TV Box...
I just need a power supply cord to charge my jump starter system. Where can I get one?
Just get a generic charger from EBay. They may be available elsewhere. Get a 12 volt 500-600 milliamp one or if you know the exact milliamps for your charger, use that number. Here's a link to one on EBay.
I'm not recommending this particular one, just using it as an example. Good luck!
Mar 09, 2010 | JUMP START SYSTEM
What adapter can we buy to plug the venturer portable dvd player into a household mains plug. It only come with the 12v lighter car adapter
What I did with mine is check eBay for a 12 volt, DC LCD monitor adapter. These normally have sufficient amperage to handle these players.
I did a search on eBay today using search phrase:
"new power supply ac adapter for LCD monitor 12v 5a"
and came up with one for about $14.00 with shipping. You will need to check the plug when you get it and, if it does not fit, get one from Radio shack or, as I did, cut one from an old adapter I had laying around.
Most of these units require that the positive side goes to the center conductor of the plug (check the diagram on the player case over the plug to be sure) so make sure you set it up the way the diagram shows or very bad things will happen to your player.
You may be able to find a 12 volt adapter at Radio shack or somewhere else but these units need (according to the specs) about 1 amp from the supply to work and charge correctly. You "may" be able to get by with an 800 milliamp supply but I have not tested this.
Good luck
Dec 28, 2009 | Venturer PVS177W Portable DVD Player
What is the dc input for JBL Media 100
They run @ 12 volts 850mA. So an adapter with center pin positive at around 1A(1000mA) would give it enough "headroom". This means it would run cooler and last you longer. Amperage consumption is determined by the power it is producing, how loud you are playing the setup.
Mar 13, 2009 | JBL Media 100 Computer Speakers
Got flat screen as a gift
This monitor requires a power supply with a POSITIVE tip polarity.
Monitor requires 12 Volt DC @ 3.3 Amps output.
Make sure voltage is 12 Volts DC [absolute requirement]
Power Supply can have greater than 3.3 Amp capacity. More amp capacity increases price, so I wouldn't go for more than 5 Amps [minimum 3300 milliAmps, 5000 milliAmps will be more than adequate].
Put a surge protector on your computer and monitor to extend their life....better yet, a power conditioning battery backup system, that can supply constant voltage, to compensate line voltage when A/C, furnace, or other major appliance kicks on.
May 04, 2008 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Jensen VM9510 Car DVD Player Logo
97 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
