Question about Sony Handycam DCR-TRV250E Digital Camcorder
Not recording clear.
I have had my digital camera for approximately 4 years going on 5, I have never cleaned it in all the history I have had it, however up until a couple of weeks ago when I pulled it our & tried to record something, the LCD screen had "Cassett Cleaning" across it, & then it automatically switched off recording mode, however whilst this was happening it had a beeping mode. I have since tried cleaning it several times, & it has done wonders for playing back tapes I previously recorded, however if I try to record something new, & then play it back it has grey lines appearing through the picture. What could this mean?
    Sergeant:
    Champion:
  • 326 Answers
Hello, please try to playback these new recordings on some other Camcorder. If you experience good picture on the borrowed Camcorder it means that the video head is (partly) damaged. In order to cure this the video head is to be replaced. Please contact the Authorized Sony Service or the technician with the best references. Best regards, Arpi
Posted on Apr 18, 2007
Camera is telling me 'change the battery pack' but both of the battery has been fully charged (and the spare battery). Camera and batteries are approximately 5 years old.
I have had this same problem with Canon digital cameras. It seems that either the contacts in the camera or the batteries make a weak contact. On one such camera I can move the battery cover back and forth across the batteries and it will sometimes made good contact. Try cleaning the batteries with steel wool. I am not sure how you can improve the camera's contacts.
Mar 22, 2016 | Canon PowerShot SX10 IS Digital Camera
Nokia XpressRadio 5030 phone keypad is not working properly, problems as follows. 1) top right button does not show go to menu but shows digit 8 and disappears 2) Clicking on 2 digit number appears 23...
  • if phone has history of getting dropped to the floor or banged hard, this could cause the keypad contacts to misalign
  • try opening the case and cleaning the keypad contacts
  • best solution is have it checked by nokia service center tech support
Oct 02, 2010 | Nokia XpressRadio 5030 Cell Phone
Camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 29, 2009 | Canon PowerShot S3 IS Digital Camera
When I turn on my EasyShare M863, it turns off again. I have tried to change the battery, etc. But nothing has helped. I was going to send it in for help, but cannot locate an address. I received this...
1. Remove the batteries from the camera then clean the battery contacts
2. Remove the memory card
3. Insert the battery back on the camera in correct position
4. Place the camera in Auto Mode (auto mode is the green camera icon on the dialing mode)
5. Try to turn it ON (if still doesn't turn ON)
6. Charge the camera plug the USB AC adapter into a working power outlet.
7. Connect the USB cable to your camera and to the USB AC adapter.
8. Camera will charge until light turns off or (up to 3hours) then test the camera if it will turn ON
9. You can also check http://www.kodak.com/go/usbcharging
10.You can also follow the steps on this website www.kodak.com/go/stepbystep
**Contact Kodak support line 1 800 235 6325 (23KODAK)
kodak camera warranty is one year from the date of purchase or from the manufacturing date which ever is longer
Nov 16, 2009 | Kodak EasyShare M1033 Digital Camera
Removed battery cables to clean them, car won't start. dash says service anti theft system. what can i do?
Ignition keys relearn takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself.
Nov 16, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
Will not record says disk full cannot clear the disk
You need to go into the menu and format the disk. If you need more help, let me know what the model number is.
Jan 30, 2009 | Swann Communications Swann S243 16u 11111...
Not recording
What camera are we talking about here? Have you tried resetting the camera?
J. DeRuvo
Digital Camcorder HQ
Dec 04, 2007 | Video Cameras
Record the image
Full size image: Approximately 48 seconds for Super Fine images, 5 seconds for Fine, 2 seconds for Standard, 1.5 sec for Economy Half size image: Approximately 12 seconds for Super fine images, 1.8 second for Fine, 1.5 second for Standard, 1.3 second for Economy. The recording time may vary according to the scenes.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Boot the camera?
Start-up time for the DiMAGE E201 is approximately 4 seconds in recording mode, and 3 seconds in playback mode.
Record mode
2288 x 1712 SHQ, JPEG - approximately 1960 Kb 2288 x 1712 HQ, JPEG - approximately 762 Kb 1600 x 1200 SQ2, JPEG - approximately 465 Kb 640 x 480 SQ2, JPEG - approximately 72 Kb 320 x 240 HQ Movie - approximately 12.5 Mb (20 Second Movie) 320 x 240 SQ Movie - approximately 12.5 Mb (41 Second movie)
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Sony Handycam DCR-TRV250E Digital Camcorder Logo
127 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
