Question about Motorola Radio Communications
Part # for an XTL 5000 w-7 control head. H1517A or H1764?
I am trying to get a second control head for the XTL 5000. I got 2 different part numbers from 2 different Motorola Dealers, H1517A & H1764. Which one is the correct one? Thank You for Your Response, Captain K Carpenter
  • Motorola Master
  • 1,654 Answers
H1517A is listed as a ASTRO SPARE CTRL UNIT W7 FAS. H1764 is listed as a W7 DUAL CONTROL HEAD RETROFIT KIT. You would need to call Motorola to confirm, but it appears one is the number used when you order it with a new radio. The other is the number you use when ordering for a radio you already own. It is unclear what the difference is. The H1764 is significantly higher in price.
Also, the dealers quoting you the W7 may be able to clear this up for you. The XTL5000 is an APB item and not in the standard dealer book.
Posted on Dec 27, 2008
^where do I get a propelling belt for ROVER QUANTUM XTL model no. 07032
-Have you try at ACE store ? Or try Amazon if you have the machine's model number.
Good luck
Mai
Dec 12, 2017 | Garden
Motorola radio set XTL 5000 audio is not comming spk cables are ok. Main cct board is faulty.whst I do pl help me
Check that you have the radio set to message trunking. it sounds like your in transmission mode.
Nov 10, 2014 | Radio Communications
Have xtl 5000 says key failed but do not have key loaded
Mine says key failed, too, because it's expecting to find an encryption key, but there isn't one. I ignore it. I could make it go away either by flashing a key into it or else by unchecking the Secure Hardware Equipped check-box using the computer software for programming the radio.
Jul 10, 2013 | Motorola Astro Xtl 5000 M20urs9pw1an...
05/94 error on 05 control head
This error message indicates an incorrect connection from main radio and your remote head, Check that you have installed correctly and that all plugs and fittings are snug and not loose.
Otherwise, the remote is cactus, that could be another issue, try without the remote and see if the radio works, the answer lies in either of those.
Hope this helps you.
Cheers,
Peter
Nov 01, 2012 | Motorola Astro Xtl5000 Model M20urs9pw1an...
There is a sequence and it is 2,8,18,32,50,72 what is the fiftyiest number
The pattern for this sequence is that the difference between one number and the next is four more than the difference between that number and the previous one.
For example:
8 - 2 = 6
18 - 8 = 10
32 - 18 = 14
50 - 32 = 18
So the sequence is:
2, 8, 18, 32, 50, 72, 98, 128, 162, 200, 242, 288, 338, 392, 450, 512, 578, 648, 722, 800, 882, 968, 1058, 1152, 1250, 1352, 1458, 1568, 1682, 1800, 1922, 2048, 2178, 2312, 2450, 2592, 2738, 2888, 3042, 3200, 3362, 3528, 3698, 3872, 4050, 4232, 4418, 4608, 4802, 5000, ...
So the 50th number in the sequence is 5000
Nov 07, 2009 | The Learning Company Achieve! Math &...
Need a code for my 5000 RDS EON Radio Cassette please
Try code 3138
Ford  Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
Oct 27, 2009 | Car Audio & Video
Xtl head shows "maintenance mode" "remote device" is it not programmed? Also is control head wiring red 12 volt and yellow ign.?
The red wire on the remote head should go to the battery (with a fuse inline) the yellow wire should go to a switched 12 volt source (with a fuse).
The XTL radio is in need of correct programing, With out looking at the codeplug I would say that the option for remote head was not checked.
Hope this helps, Bill
Aug 22, 2009 | Motorola Radio Communications
How to unlock Nokia 6300 phone
Try code number 7 first. If it does'nt work, try code 1. Different codes work on different phones. Remember that you only have 5 tries.
To enter the code:
1. Push #
2. Push * 3 times in one second. (p will show)
3. Push * 4 times in one second.(w will show)
4. Push * 2 times in one second(+ will show)
5. Enter the code from below.
6. Push * 2 times in one second.(+ will show)
7. Enter the code number
8.Push #
Now a message like "Sim restriction off" should be displayed. That means your phone is now unlocked.
Your code's are:
#pw+228875557620475+1#
#pw+436867161410263+2#
#pw+494327720215623+3#
#pw+315916340311414+4#
#pw+183024315162023+5#
#pw+947802170570602+6#
#pw+493267323124160+7# <<
Feb 12, 2009 | Nokia 6300 Cellular Phone
MOTOROLA XTL 5000
Hello BSEESTADT, The info displayed is telling you to "carry me to the radio shop". When did you buy the unit? Did you purchase a service warrenty? Call your local Motorola shop and ask for a technican not a manger or sales. He may do it for free or maybe a discounted service charge. If a charge is out of budget call some other radio service shops for cost. Good Luck
Nov 06, 2008 | Motorola Radio Communications
My camera doesn't record!!!
it may be a corrupt driver or a software glitch, remove the camera from usb port,uninstall driver and software and reinstall. Try camera in a different usb port and record again to see if the same thing applies. You can also try recording in windows movie maker 2 to see if the same problem occurs, atleast then you will know if its a camera hardware fault or not after trying 2 different recording programmes.
May 07, 2007 | Logitech QuickCam Pro 5000 Webcam
Radio Communications Logo
363 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
