Question about Audiovox XMCK10 Satellite Radio Receiver
Audio When activated it loaded and played through tv. Sound was fine. I disconnected that night, I have pets and didn't want them to knock it off onto the floor. Next morning I reconnected it. Turned it on and there was no sound. The audio level showed it to be good but no sound from the tv speakers. Even tried a different tv
No I did not solve the problem but I will simply by taking the radio back and gettign my money back
I'm sorry, I have no intention of spending more money to find out how to fix a faulty radio which may not be repairable to begin with.
Posted on Dec 28, 2008
I awoke this morning to find the sound on my Apex Digital LD4088 LCD tv is dead. The picture is fine, but sound is dead, how do I solve this?
Download the user manual to your TV. Clik here to download it. See whether audio options to it are set right. If all are right, check its speaker. If speaker is OK, the audio output circuit section should be troubleshooted.
If you feel any difficulty in downloading the manual, send your email address to me. I'll send a copy of it to you by return mail.
May 16, 2012 | Apex Digital LD4088 LCD TV
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My power went of a for about 8 hours last night and when the power was restored everything works except I cannot hear sound on my BT730 sound system while listening to TV through the cable box. I can hear...
Trace the TV audio back to its source - TV or Cable Box most likely. We have no way of knowing which. Substitute in another source to test the input.
If DVD audio works so does the basic HTS.
Sep 07, 2011 | Panasonic Home Theater System System
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
Turned off TV last night turned back on this morning and there's no sound. Played x box on the TV and it had sound. Now no sound again.Checked all settings and everything's the same. What can I do now to...
You will need to open the rear panel after disconnecting the power. Check on the audio amplifier for output, check for main voltage on the output, check the speakers, use a multimeter to probe if you are familiar,Try to inject an audio signal to find the section which will not respond. Once the section is isolated the fault can be zeroed in for confirmation.hope you try.Godd day
Aug 06, 2010 | Sony KV-24FV12 24" TV
Memorex mvd2047 dvd player - no audio when playing dvd
Regarding the problem with the sound on your DVD player, I would suggest you to make sure the audio cables (red and white) are connected properly to the TV and player.
Also, try using a different set of cables since those ones might not be working and this is why you are not getting audio. On the Memorex remote you will find a mute button, make sure it is not activated.
Jul 23, 2010 | Memorex MVD2047 DVD Player
No sound from any source from speakers
check your connections again and ensure you have the audio going out. With many tv's you need to change a setting in the menu, double check that as well.
May 05, 2009 | Denon AVR-687
Playing the sound of tv through the sound bars speakers
Not sure for the playstation etc, but for the TV the manual says using the (not included) optical link between TV and the main unit.
Note that this is not mentionned in all language versions of the manual.
Apr 10, 2009 | Samsung HT-X810T Theater System
Suddenly no sound from playiny tv through the dvd
check SCART lead hasn't come out....even a slight amount will disconnect the audio pins
Check the function / to others / setup / connection / AV1 & AV2 settings
Feb 15, 2009 | Panasonic DMRES20D DVD Recorder
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
Audiovox XMCK10 Satellite Radio Receiver Logo
109 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
