Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
TV will not turn on
We lost power the other day and once it was restored our tv will not turn on. When I press the on button the red timer light just blinks.
  • Gary Hinkle Dec 31, 2008
    I have the same t.v.,and the same exact problem.Have you had any luck yet?
    Sergeant:
  • 280 Answers
Replace shorted Q431,can use a 2sc3998, open r448 .47ohm resistor. after you get set on beware of convergence ic's may have been shorted causing all the problems.Check r859 &r858 .47 ohm 1 wtt that supply - &+ 20 volts to convergence packs, if open replace packs & check low ohm resistors on convergence ,I found r2144 &r2145 open replaced & all systems go "good luck"
Posted on Jan 03, 2009
I have lost the remote control now the tv will not turn on
The remote should not have any effect whether the T.V. turns on or off.
Have you tried to press the power button so that the standby light is on? On most Tv's the light should be red. Once the standby light is on press the button on the TV to change the channel, either the + or - button. This should switch the tv on.
May 03, 2011 | Televison & Video
Tv wont turn on. red timer light blinking. i think our baby hit some magic button.
I have a Sony Trinitron KV-35S66 36" TV my Stand by/Timer Light keeps flashing, I have tried all fixes, it's 9 1/2 years old is is worth fixing/cost.......no money!!!!
Jan 02, 2011 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Need help
Here are the codes, 006,007,010,011,013,016,027,033,035,043,066,087,089...Turn the TV on, press and hold the CODE SEARCH button until the light turns red, press TV, the light will blink once and remain on,enter one of the three digit codes, the light will go off, if the light flashes instead of turning off, try another code until it does, press the POWER button, the TV should go off.....hope this was helpful...
Apr 18, 2010 | Philips Universal PH301S Remote Control
I cannot find my instrution manual. Help!
Here are the codes, 002,003,004,005,104,105,106,115,205,204,206,213,304,305,316,319,405,502,505,506,519,604,605,705,804,805,903,904,905,906...Turn TV on,aim the remote at the TV,press and hold the code search button until light turns red,press TV,the light will blink once and remain on,enter one of the three digit codes, the light will go off,if the light flashes instead of going off, you need to try another code until it does,aim the remote at TV and press POWER button, the TV should turn off....hope this was helpful...
Apr 17, 2010 | Philips PM335 Remote Control
Lost my manual of my Jumbo Universal Remote. I would like to know the 3-digit code to activate my JVC TV, Model I'Art Pro
Here are the codes, 013,054,055,060,065,067,089. Turn the TV on, aim remote at TV, press and hold the CODE SEARCH button until the light turns red, Press TV button, the light will blink once and remain on, enter one of the three -digit codes, the light will go off, if the light flashes instead of going off, you will need to try another code until you find one that does, aim the remote at the TV, press POWER button, the TV should turn off.........hope this was helpful....
Apr 17, 2010 | Televison & Video
Brookstone jumbo remote control - 2006, I've lost the manual on how to program it to my parents RCA tv. It does not have a code search button on the remote itself.
finally found answer online... power off the TV press the tv/dvd/aux/etc button until the red power light turns on and stays on, then press the power button on the remote one time, then once it's on use the channel up/down button pressed repeatedly until the TV turns on, then select input to store the code.
Feb 16, 2010 | Televison & Video
I have an innovage jumbo remote did not loose it!!! LOST THE DIRECTIONS TO PROGRAM IT.
You can program the Innovage Jumbo Remote by entering three digit codes, or by using the auto-search function.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Oct 31, 2009 | Innovage Jumbo Remote Control
Programming the innovage remote
  1. Turn on your TV.
I hope that helps.
Oct 04, 2009 | Innovage Jumbo Remote Control
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
I lost my sylvania remote and bought an RCA universal remote
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
Mar 07, 2009 | Zenith DBZN-311 Remote Control
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
