Question about Samsung SyncMaster 753S 17" CRT Monitor
Hi iwant connection port map
Hi please help me for find connection map
my cable is complet cuting form my prot of behind my pc
now i make a port and 9 wire form prot of back my pc and now iwant connect my monitor cable wich color is
My mobile is not responding to connect with pc via data cable
first you know about your mobile company name and then mobile pc suite is install in your computer and then connect with your data cable through your mobile even though if not conncet then try to change your mobile data cable incase data cable is good then at that situation you need to see mobile prot
in case of mobile port problem then give your mobile to mobile repair shop
Feb 22, 2011 | Computers & Internet
Timeout 254 'Unkown Garmin' error
Try connecting it to a different USB port. Every time you switch the USB port a device is connected to, it will completely reinstall the drivers and reset.
Aug 16, 2007 | Garmin eTrex GPS Receiver
What I need to buy to connect my pc to my T.V.
Just make sure you bought the TV with RGB input ( VGA port on pc). And buy also RGB / VGA cables ( otherwise, if able , just take it form pc monitor).
Connect VGA out from your computer to RGB in on your TV. now they are connected and your tv is computer screen now.
Regards, vote it please, Jay
Jan 21, 2011 | Computers & Internet
Where do i land wire off of modem on linskys? where do i land wire on lynskys headed towards computer?
Hi on the back of the router there will be a number of ports
in the section of prots numbers 1 -4 you need put one end of a network cable (RJ45) into there and the other one will go into the back of your PC/Laptop in the LAN 10/100 interface (there should be only place at the back of your PC/Laptop that t will fit)
On the back of the router there will be another port titles uplink or internet the cable from the back of your modem should go into there
Please leave feedback/vote if my answer was helpful
Feb 10, 2010 | Linksys Wireless-G Broadband Router
Most likely from tripping over cables over
Hi George
I would simply recommend having the board replaced or upgraded as its not wise to have soldered connections flying around. The only problem is that the system being that old is not going to be an easy one to source a motherboard for.
Sorry i couldnt be any more help.
Taz
Oct 24, 2009 | Dell Dimension 2400 PC Desktop
Your experts told me to change the ip address of my router. When I go to IE and type in 192.168.1.1 nothing happens. So I reset the router and tried reinstalling the software. Now on step 10 of...
first reset your router to default setting by using button behind the router in between ethernet prot and anteena using a thin screw driver or pen tip . then its default ip will be 192.168.1.1.
then first connect you pc with router using a straight cable. Set your pc ip of same class eg 192.168.1.2. then try.
Aug 20, 2009 | Linksys Wireless-G WRT54G Router
Compatibility of parallel and usb
I have Canon LBP-800 laser printer with parallel prot and have computer with USB port.
I connect my LBP-800 printer with Parallel and USB Converter but printer is not functioning. I am using Windows XP.
Please solve the problem in details.
Thanks
ishaq
Dec 23, 2008 | Canon LBP 800 Laser Printer
Computer will not completely read cd.
When you say it will not install do you mean the software stopped during install? Did windows not see the printer? With your computer running. Connecting everything for the printer. Connect the usb cable to pc & printer. Last thing to connect should be the power. When you connect the power cord & turn on the printer. Windows should show an icon by the clock. This icon is windows found new hardware. If this does not come up than your printer is either not connected correctly, you have a bad usb cable or usb port is not seeing the connection. Try another usb port. Each company has their own way to install printer software. Most want the printer shut off. During the install of printer software, a window will open and ask you to connect the printers usb or serial connector to pc & turn on power. The software will finish. Others want you to install the software completely into windows. When you shut down windows than you hook up the printer & power. If everything above failed you can try connecting the printer to another computer & you can try another printer for your Dell. I know, who has something extra like a printer you pc but this is all about trial and error.
Hope one of these suggestions work for you! Lastly, new Dell! You should have free support through dell even for things like this. Luck!!
Please vote...
map
Jan 30, 2008 | Lexmark X1150 All-In-One InkJet Printer
Samsung SyncMaster 753S 17" CRT Monitor Logo
117 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
