Question about Mitsubishi VS-45609 TV
Mitsubishi vs45609 The tv sometimes turns on and then off right away. When it finally stays on I get a green and red blur. Then I get green halos around people and words. What can it be.
  • 1 more comment
  • unfixable Nov 04, 2007
    had same problem. had new chips installed, six month later same problem
    repairman said it would cost 400.00 dollars to fit this again whats the deal?
  • Anonymous Jan 06, 2008
    We have Model # vs-45609 projection tv and for no known reson the color is out of sink or registar so there is a color gost. Solution?
  • Anonymous Mar 17, 2008
    tv-mitsubishi no power
THE BEST SOLUTION IS, FIND A ELECTRIC OUTLET THAT HAS A BETTER CURRENT! OIL IT WITH WD40 FILE THE PLUG PRONGS, IF THE ON OFF PROBLEM HAPPENS AGAIN UNPLUG AND WAIT. TURN ON THE A/C IN THE ROOM WITH THE TV SO IT DOES'NT OVER HEAT. OTHERWISE BUY A NEW TV WITH A 5 YEAR WARRA.!
HAPPY HOLIDAYS
Posted on Dec 20, 2007
  • 4 Answers
The TV turning on and off might be due to improper contact of the power circuit. The picture tube could be a problem for the improper colouring. Its right time for a good exchange offer.
Posted on Apr 19, 2007
    Genius:
  • 1,074 Answers
Have a tech check your tv it might need to be repair the problem could be in the color circuit.
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
TV click on and off.When it come on it has a green screen with lines. Stay on just for about 3 sec. than click off.
The green crt is dawning to much current, and that is why the TV is shutting down, if you remove the speaker cover, there is a focus block, that has six controls, on it three are for red blue, and green screen voltages, if you turn green down where the retrace lines go away, the TV should stay on, it is not worth fixing, you would be better off getting a new LCD.
Feb 11, 2011 | Mitsubishi VS-60707 60" Rear Projection...
Getting red, blue and green halos around images
I had a similar problem with red halos around images on my Hitachi rear projection TV. The problem was that the red convergence chip burned out. I replaced that and that fixed the problem. I found several forum posts on similar symptoms and fixes for Sony rear projection TVs by searching for "Sony rear projection convergence problem." Likely you've already tried the auto-convergence function for your set, if it has that.
Feb 28, 2010 | Sony KP-46WT500 46" Rear Projection...
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites MCMElectronics.com,Tv reapair World.com to buy CRT tube coolant to recharge ur CRT.
Feb 26, 2010 | Sony KP-46WT500 46" Rear Projection...
Convergence problem again
I think you might need to do an advanced convergence. this is done threw the service menu. it is complicated and time consuming. however there is still a possibility that the green convergence circuit has failed. there is very little green correction since it is in the middle. most sets don't even have a green convergence circuit. however this one does. these pico fuses are "tiny yellow" look like a small resistor. chech for b+ on all 3 conv.ic's.
Jan 04, 2010 | Mitsubishi VS-45609 TV
Mitsubishi TV Model VS45609 Blinking Green Light
I have a Mitsubishi VS 45609 tv. I turned it off at midnight and tried to turn it back on the next morning and nothing happens. Can you help?
Nov 03, 2009 | Televison & Video
Philips Magnavox Projection T.V
you need to replace a cople of the opticoupers most likely, if you want to repair this and save yourself a lot of dough, contact me at techman32k-at-yahoo dot com
Larry Dillon
Aug 06, 2009 | Televison & Video
The screen is starting to have red and green blurring
sounds like the coolant if it appears as halos. If it appears like a 3D picture its the convergence ICs.
Jan 30, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture turns to red & green and becomes blurred.
This is likely solder connections cracking on your convergence ICs. If you can bump the tv and it goes back to normal, it just needs resoldering, but if it doesn't, then it needs the ICs replaced. If the convergence is out, you will see a bowed picture and the red, green, and blue will be separated. Worth repairing if you can find a company to do it affordably, I can help you repair yourself if you have disassembly and soldering skills.
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi VS-45609 TV Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
