I would like to push a button or two to mute ring I would like vibrate mode to be switched on, always (can't find it) I would like to disable PTT button on the side... would like to assign that to another function. Thanks
U will have Quick setting button on top of notification panel. In that u will be having sound symbol. Click on that to change the volume modes to Ring or Vibrate or Mute.
or
Go to settings option, in that u will have Sound option. Open that. In that u can check the option Vibrate when ringing option.
It would be easier to solve this problem if you have shown the model of the cell phone you have.
However the problem is really simple.
All you have to do is to go to Tools and search for sound options or "Silent mode" another option is that you can try pressing one of the buttons (up, down, left, right) on some phones by pressing one of these buttuns you can get the options for your mobile phone, such as Viabration Mode, Flight Mode, Silent Mode or lound Mode.
Another thing that you can search for is "Profiles" this is the option that lets you to shoose any profile for your phone (it can be changed at any time) Every singe phone have different Profiles, some have alot and some have less, here are some of them for LG phones - general = Normal (loud)
- Silent = Mute (no sound)
- Vibrate = Vibrates instead of sound
- Headset = Work only when you plug
in your headphones.
Try to find any of these options...
If you still have any problems with it just ask any of your friends who has a cell phone, then they will show you how to solve it, because it is really simple.
Receiving Calls 1. To answer a call, touch or open the slide. If the slide is closed, simply slide it up. If the slide is closed, press the Voice Commands key twice, then touch . If the slide is open and the touch buttons are lit, touch . NOTE If you touch Left Soft Key [Quiet] while the phone is ringing, the ringing or vibration is muted for that call. NOTE If you touch Right Soft Key [Ignore] while the phone is ringing, the call will end.
Mute Function The Mute Function prevents the transmission of your voice to the caller. To quickly activate Mute touch Left Soft Key [Mute], then to unmute touch Left Soft Key [Unmute].
NOTE! while doing this you must call someone then while talking with him touch Left Soft Key [Unmute] to Unmute
Hope it help you out ^_^ try download the manual if you loose it http://www.cellphones.ca/upload/manuals/lg-vx-8500-manual.pdf
open up your phone then push one of the buttons on the outside edge at a time until you see the volume chart appear. Each time you push that button you will change the setting from mute to vibrate to louder and louder rings.
replace the ptt button with something else!!
