Question about Dewalt DC988kar XRP 3 - speed 1/2" 18v cordless hammerdrill/drill/driver kit
New cordless drill won't run with charged batteries
Xmas gift. Charged both batteries but neither will turn the drill in either direction. Torque settings, speed settings don't matter. Is there an internal fuse, or contact coating that might be interrupting power??
  • 2,176 Answers
Does the drill do anything? Check in the cavity where the battery goes and make sure there is nothing there to prevent the battery contacts from connecting with switch. I take it the charger indicates the batterys are fully charged. If you cant see anything obvious I would take it back and get a replacement.
Dave
Posted on Dec 27, 2008
My Dewalt cordless drill, model DC970, is fully charged and turns. However, when I try to turn a screw, the drill does not move. What should I do?
There is a collar that controls the torque of the driver just behind the chuck. Rotate it until the drill icon lines up for full power.
Mar 05, 2015 | Dewalt 18v Cordless 1/2" Adjustable Clutch...
18 volt cordless Dewalt drill does not have any torque I can stop it with my hand quite easily any suggestions
If it's fully charged and still has no torque, either replace the battery or, if you're a DIY type, disassemble the battery and check each cell under load to replace just the weak cells.
Sep 08, 2014 | Drills
My Black and Decker Drill and Hand Saw have brand new battery pack and brand new charger to BE SURE battery is fully charged but still don't work
it is probably the brushes on the motors are wore out or stuck and not making contact. pretty much junk unless you feel confident enough to attempt repair.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Black & Decker Black and Decker 18V...
Black and decker drill runs slow
Its much more likely that your batteries are not charging up properly. Ni-CD batteries suffer from 'memory effect' and can appear fully charged when only 70% charged. Also they lose charge when being stored. Do not short them out to discharge them! Wait until the drill complains that they are flat and then recharge them rather than when they first start to slow down. Do not let become completely flat (less than 1 volt).
Mar 03, 2013 | Black & Decker Black and Decker 18V...
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
Brand new hitachi 18v, one battery charged fine the second is completely dead it was in the drill from the factory and the charger won't recognize it when attached.
I have just had a similar issue I left the drill unused for a period and when i placed it in the charger the charger showed the battery as charged after about 15 secondseconds.
Following a internet search i found a site that suggested for a imlar problem with a camera jump starting the low battery with a 9 v battery. I had a spare from the drill which was fully charged so placed a contact from + to + and - to - and held for about 2 mins. I then placed the battery back in the charger and it started charging. Running the battery down as we speak to recharge again well worth a try. If you dont have a spare maybe the 9 v would work
Sep 03, 2011 | Hitachi DV18DL 18V Liion Cordless Combi...
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Aug 22, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drill will not operate. I charged batteries but still will not operate. Is there an overload reset?
Just try to buy a new battery and test.If persist,change the charger. Bet the bats are dead.
Nov 10, 2010 | Hitachi DV18DVC 18V Cordless Hammer Drill
Was given a drill as a gift about 3yrs ago, tryed it for the first time recently. problem the charger doesn't charge the battery, had the charger checked and it is only putting out about 4b volts. How can...
After 3 years you probably can't get any kind of warranty support but you may be able to repair the charger or buy a universal one. www.centurytool.net sells parts for battery chargers....if you know where the drill was purchased, like sears, you may be able to take it there and they can either send it in for repairs or point you in the right directions. Most cordless drill batteries will go bad if they are not charged regularly so you may have to replace them also. Good luck!
Nov 29, 2009 | McCulloch Drills
Dewalt DC988kar XRP 3 - speed 1/2" 18v cordless hammerdrill/drill/driver kit Logo
231 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
