Spinning but not draining kenmore elite 20052
The washer is spinning but not draining and it stays on 8 min. What is the solution?
  • 198 Answers
If this is a front load washer you will need to check the drain pump which is electrical. If the pump runs there is a blockage somewhere.
Posted on Jan 05, 2009
    Genius:
  • 1,665 Answers
Hi have a nice day.
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
For more informations see link below.
http://www.repairclinic.com/0088_11_1.asp#Level1_2
Posted on Jan 02, 2009
Washer not spin
I have a Kenmore 60 sirce washer it drains put won't spin
Dec 07, 2013 | Kenmore 24032\24036 Top Load Washer
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer sm 9711034, washer will not go through spin cycle at end of wash cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 19, 2011 | Kenmore Washing Machines
Kenmore Elite HE3 will not spin, sounds like slight gear slipping
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Kenmore Elite 45986 Front Load Washer
Washing machine isn't spinning clothes.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Nov 20, 2009 | Kenmore Elite 45986 Front Load Washer
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
