Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
WHIRLPOOL dishwasher 4404/5.
Thanks your answer but float in salt tub in ''now'' floating freely(wasn't before) however light still flashing 4 times.
any suggestions?????
help.
thanks
    Genius:
  • 1,550 Answers
The water pressure is not upto the mark in your dishwasher , try switching it on when there is no other water being used.
Posted on Dec 27, 2008
Clean light is flashing
please read your instruction manual and go the section troubleshooting
press down the overfill protection float on the floor of the dishwasher's tub in the right, front corner near the door. If it cannot move up and down freely, the "clean" light will flash.
Jun 21, 2012 | KitchenAid KUDS30IVBL Builtin Dishwasher
Dishwasher runs but no water comes in the dishwasher. Checked water supply, good up to begining of solnoid, but water doesnt go through it. Model DU810SWPQO WHIRLPOOL 2004
Heres what to check
FLOAT IN TUB...check it for sometime stuck under it, or it stem under float is gummed up
FLOAT SWITCH....if float is down and moves freely check for continuty on float switch
WATER VALVE ...check for 120 volts ac into wires on valve solonoid when supposed to be filling,
it's supposed to fill and beginning of cycle
Gene
Aug 14, 2011 | Dishwashers
Hi, I am not getting any water going into the machine when I put it on a programme. It starts and when I go back to check it 5 - 10 mins later it says its finished yet everything is still dry and dirty....
It sounds like something may be stuck under your fill switch float. This is usually located near the door, and sits in the bottom of the tub. You'll need to remove the bottom dish tray/basket to get at the float.
Usually, the float is cylindrical, with a magnet inside. It slides up and down a tube which has a magnetic switch inside, which is operated by the magnet in the float traveling by it as the water level in the tub rises and falls. The switch operates a solenoid operated valve which allows water into the tub. This float switch also tells the system when all the water has been pumped out after a cleaning cycle in some dishwashers.
Occasionally, something will get stuck under the float, such as a piece of broken dishware, or a wheel off one of the basket rollers, to name just two items. If this happens when the water level is up, it seems to the dishwasher that there is water in the tub, even when there isn't any, and it proceeds with a wash cycle, but without water, resulting in dirty dishes and a dry inside-of-the-dishwasher.
If you don't find anything under the float, make sure the float travels up and down the tube freely, as it's getting stuck on a dirty tube will cause it to hang up. Clean the outside of the tube and the inside of the float with a piece of Scotch-Brite; NEVER use steel wool, brillo, or anything else which could leave magnetic materials on the float or tube, as they could affect the operation of the magnetic switching operation.
Always check your owner's manual for solutions to this type of problem, and other good maintenance tips.
Alec
Jun 04, 2011 | Dishwashers
On my Dishwasher Miele G638 Plus, a red light shows up and it says PC salt, I dont know how to solve this, please help me.
Hi - its possiblily the following issues if its flashing rapidly then the electronic module maybe faulty. The other possibilties are the float switch inside the salt conatner is jammed or the reed switch for the float switch in the salt container does work.
May 30, 2011 | Miele 24 in. G638 Plus Free-standing...
Little water being pumped in.
Make sure the hot water supply is turned on all the way. If that isn't the problem, check the float on the front floor of the tub-make sure it moves freely up and down, and it should click when it moves. Remove float and clean around the float tub-you may need to do this from below, through the access panel.
Shut off the hot water, pull the front panel, and find the water intake valve. Take this apart to the screen and clean the screen.
If none of this works, you will need to call a repairman
Sep 19, 2010 | Whirlpool Dishwasher Pump Motor
My dishwasher keeps adding water and overflows
If the water lifts the float all the way up or the float is submerged, the water level is too high. Overfilling is likely a problem with the float or float switch. The float is located inside the dishwasher in the tub area. As water enters the tub, the float device will rise. When the float rises to a certain level it triggers the float switch, which in turn, turns off the water flow. In some dishwashers, the float switch is only used to prevent overfilling and the amount of water is regulated by the timer.
Before testing the float assembly, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
To inspect the float assembly, open the dishwasher and remove the bottom rack. Remove the float cover (if any; it can be identified by the fact that the cover does not move up and down). The cover may snap in place or it may be fastened in place with a screw.
Lift and drop the float several times. It should move freely. If the float sticks, it may prevent the dishwasher from filling or draining properly. Remove the float and look for obstructions that may interfere with its free movement. The float usually snaps in place. If it does not come off with a small force, it may have to be disconnected from the float switch first.
You will need to Replace the float and float cover, If you found no obstructions and the problem persists, test the float switch.
TESTING PROCEDURE
To access the float switch remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
Note the location of the float in the dishwasher's tub and you will find the float switch beneath it in the access area. The switch has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. With the probes still in place, depress the button or lever on the switch and the reading should change to the opposite extreme.
If the switch fails either test, it should be replaced.
NOTE_ If the float, and float switch check out ok, and there are no issues here, the culprit will be a faulty water inlet valve. replace the valve in this case.
Nov 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water keeps running into dishwasher causing overflow
I had a diswasher with thils problem several years ago. The problem was wiith the plastic float at the bottom. It had hardend greese buildup that kept the float from moving freely. Removing the float and cleanning fixed the problem.
Jan 29, 2009 | KitchenAid Dishwashers
Hello.have whirlpool dishwasher 4404/5. green light flashes x 4
sorry...
This is the WRONG PLACE for paid advise...
You need to contact the CLOWNS who charged you...!!
FIXYA is entirely FREE... (all volunteer)...
Not ever to be confused with money grubbers...!!
Good luck with your scammers.
Carnac the Magnificent
Dec 03, 2017 | Whirlpool 24 in. ADP5962 Free-standing...
The salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Mar 30, 2007 | Baumatic 18 in. BDW45.1 Built-in...
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
188 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
