Question about HP Espow----Replacement for COMPAQ BUSINESS NOTEBOOK NX9000 SERIES Laptop Batteries
Battery replacement how to change the new battery from espow for dell latitude D610,computer is funny,wont even start windows after i put new battery,light is flashing orange and green,source is saing 100%,but if i disconnect charger laptop die immidietly..plz help
Seems to be a problem with that laptop battery, maybe you should contact the seller directly.Hope that helps.
Posted on Mar 06, 2009
  • 139 Answers
There is a battery lock at the bottom of the laptop and u need to move that lock and battery pops out
Posted on Jan 08, 2009
Dell D610 has started all of sudden switch off its self, after replacing bottom casing. But its starts normally after switch it on after 2 to 3 seconds
Take the battery out of the computer.. Unplug the laptop out of power source... Press and hold the turn on key for a while... Then put the battery back in place.. Put the adaptor back.. try to turn on.. If still not fixed. its a hardware failure...Contact Dell 18006249896 or a local technician
Dec 21, 2010 | Dell Latitude D610 Notebook
My dell latitude d610 is not charging, when connected with ac adaptor the laptop works fine even without batter but putting up the battery shows-charging is nil ! -updated my bios with a06 version from...
Hi, you might just have a faulty battery and need to replace it. One thing you can try is to stick the battery in your freezer for a day or so, and then put it back in your computer and see if it will charge. If not, try a new battery and you should be okay.
Oct 03, 2010 | Dell Latitude D610 Notebook
Window wont boot on dell latitude d610, system restore, safe mode wont work, cant even reformate the commputer
there could be a posibility that the harddrive of the laptop is damage and needs to be replace. you already tried to reinstall the operating system but it still wont work in that case try to replace your harddrive.
Feb 20, 2010 | Dell Latitude D610 Notebook
Dell Latitude D610 goes off after booting to XP. Changed RAM,Changed Battery,Changed battery, Changed Harddisk,Changed OS..All to no avail.
If you are still covered by the warranty, tell dell techsupport all the parts that were already replaced, and i believe the next part that needs to be replaced is the Motherboard, and heatsink. Hope this helps
Dec 14, 2009 | Dell Latitude D610 Laptop Computer -...
Dell Latitude D610 Shuts off with no warning...
the problem is not the battery; what has happened is the coolant paste that pulls the heat away from the cpu (main) chip to the fan has dried up. you must remove the fan/heat exchanger off the motherboard and, put new paste on the chips that the heat exchanger sits on
radio shack sells the paste
Aug 29, 2009 | Dell Latitude D610 Notebook
Dell Latitude D610 wont charge
the charging system on your motherboard has blown a capacitor, if it is still under warenty you should call 1-800-456-3355. to get it repaired.
if it's out of warenty, they can help you buy the right part
Aug 14, 2009 | Dell Latitude D600 Notebook
Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
Jun 03, 2009 | Dell Latitude D610 Notebook
My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Feb 22, 2009 | Dell Latitude D610 Notebook
Dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Nov 26, 2008 | Dell Computers & Internet
HP Espow----Replacement for COMPAQ BUSINESS NOTEBOOK NX9000 SERIES Laptop Batteries  Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
