Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Igniters won't stop when pan on high output burner on high
When I place a pan on the high output burner (front left) turned to high, all the igniters begin to start.
  • 183 Answers
This is caused by the ignitor not sencing the flame or the burner requires cleaning. Regards Engineer
Posted on Jul 28, 2007
Electronic igniters will not turn off when the gas burner lites. all four igniters run untill you turn off the nob or unplug the unit
I'm dealing with this same problem. This cooktop has a dedicated simmer burner which is the only thing going on the lowest setting. This simmer burner seems to be how the igniter senses that it can stop. If it doesn't light, the igniter keeps clicking. Usually cleaning the burner will solve this. You may need to unscrew the nut holding the lower piece of the burner in place in order to clean it up.
Apr 17, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
The igniters on the left side on my Tappan gas range.
may need to disconnect voltage to machine,and check for a loose wire to burner knob.may need to lift top.to access this area.
Oct 09, 2009 | Kitchen Ranges
My whirlpool range ss630per-1 burners will ignite except of front right which give no ignitor sound at all, but the Rear Right works fine. any solutions?
Each burner control knob has a built-in switch that controls the igniter. It appears the front right burner switch in the knob is possibly defective. They are replaceable but it requires dis-assembly of the range front. Are all the igniters in a sequence? Have you tried turning the front right burner on while another burner has the igniter on. This may let you ignite the burner automatically. When you have another burner igniter clicking try turning on that burner. If the range has rectification igniters that will not work.
Sep 26, 2009 | Kitchen Ranges
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
Stove top igniter won't stop clicking
I found this on Youtube... I thought it might have to do with a thermal sensor not working properly.
Anyheuw, watch this video and see if this doesn't help fix your issue. If not, please respond and I will look at the schematics for the board as you may have a relay or some capacitors going bad.
Aug 14, 2017 | GE Kitchen Ranges
Burners won't light
Sounds like an igniter problem. Sometimes the tips of the igniters burn and don't give out the spark to light the burners. Check for a spark from the igniter on the front burners. Also sometimes the igniters drop down a little - may just need re-positioning. Compare the front igniters with the back to see how they should spark. You may need to replace the front igniters. Hope this helps.
Regards
Bryan
Feb 19, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter issue - some do not turn on other do not turn off
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Sep 25, 2007 | Thermador PC366BS Stainless Steel Gas...
Tappan TGF657
Chek wiring on your right side switch....if the wiring is Ok, replace the switch....
Aug 30, 2007 | Tappan TGF657 Gas Kitchen Range
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
145 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
