Question about Powermatic 15HH 15" Deluxe Planer w/ Byrd Shelix Cutterhead 1791213
Planar adjustment loose
My powermatic 15" planar does not hold a parallel line. That is when you run stock through the machine the vibration causes the table to open as the wood moves through. Therefore I get a cut the is correct at the front and opens up increasingly towards the back. The locking wheels at the back of the machine no longer lock the table in place.
  • Rick Wymer
    Rick Wymer May 11, 2010
    "Vibrations"?? What kind of Vibrations, and How Strong?? I have a Commercial 20" Planer, and I have practically No Vibration at all. I also have a 8" Planer, and the Same thing, very minute vibration...sounds like you may have other problems that are leading up to this??
  • 32 Answers
Well I Researched Your Problem (I'm assuming since you didn't specify, that Your Talking about a Model 15HH?), and Have come up with this, you may want to go to this site, and Check What they have for a Operations Manual.
http://www.powermatic.com/Products.aspx?Part=1791213
There's some Great Info in there for Accurate Adjustments of the Machine.
You may choose to use the "Contact Us" on that Page, and Have them assist You.
Hoping this assists you with this Problem.
Posted on Mar 07, 2009
Vibrates real bad in spin mode.
Check to see if the washer is level, and adjust the leveling legs if necessary. Always lock the legs in place after adjustment to keep them from getting loose as they do work themselves loose during heavy vibration conditions.
The following items could cause the vibration problem:
1. Clutch assembly
2. Vibration dampers that support the tub. Should one or more be faulty, always replace all four simultaneously.
Feb 24, 2016 | LG WFT1071TP Top Load Washer
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
Owners Manual for powermatic 72-ta
Type in owner's manual powermatic 72-ta in Goggle. The second one pdf looks good. Download your free manual.
Feb 17, 2012 | Powermatic Saws
The drum spins wildly out of balance to the point that it wears away the hard white plastic shield at the front. Is there some alignment guide that may need to be adjusted
this is usually caused by uneven loads. if your sure the the loads are evenly balanced check under your washer for loose or dropped parts
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Belt for Powermatic 15" Planer (Planer Model M-0460213)
Order the first one through Powermatic, then order any new replacements from the number on the belt. Or you can measure the pulley belt width and use a metal tape measure to find the total length by running the tape (number side in) over each pulley rim. Then order as a standard hardware source belt. Make sure the motor is bolted down about midway in it's mounting slots when measuring.
Sep 07, 2009 | Powermatic 1791210 Model 15S Deluxe Planer
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
Sander kick out
I cant find anything on the powermatic tool that you listed, but is this something recent? Look at the nameplate on the machine and if it a large unit it would probably say around 15-20 amps but to start the unit sometimes it pulls more than the listed rating and could be causing your problem. Check the outlet that you have it plugged into, is there anything else online with this that would draw a lot of current when starting e.g. freezer. If you can provide me with some more data I will check other floor sanders and see what I can come up with.
Feb 05, 2009 | Powermatic Tools & Hardware - Others
Vibrating badly at full speed
I do not know your machine but I used a STARRITE and had the same problem. My technician could not get it to run quietly and refused to use it. I took time and went through all the adjustments. Make sure you set the correct tention for the blade you're using. Make sure the blade just touches the support bearing. There are lead blocks top and bottom. The blade must run smoothly between these, but just. After about 45minutes I had it running quietly
The problem can also be caused by a blade that is too big (thickness) especially if it was under tention for a long time and not being used. The blade presses the rubber on one side of the wheel which causes it to be off balance at speed but that is supposed to normalise after a while.
Oct 16, 2008 | Powermatic 1791259/Model 2415 3HP 1Ph 230V...
Planar DS-15 Outside repair person
In order to provide a few pointers, you need to indicate where these units will come from. Do you plan on shipping out for repair or are you looking for a local repair shop? Where are you?
A contact email?
Dan
Mar 19, 2008 | Computers & Internet
Washing machine stops in middle of spin cycle, have to pull control knob out over and over to complete cycle.
If the machine restarts immediately, vibration may be disabling the door closed switch. This switch is designed to stop the machine when the door opens, and if it becomes misaligned any large vibrations may cause it to sense that the door is open. This will not happen usually under the relatively mild vibrations from the wash cycle. Try running it while holding the door down. It can be adjusted but the top usually must be removed to do so.
Nov 30, 2007 | Washing Machines
Powermatic 15HH 15" Deluxe Planer w/ Byrd Shelix Cutterhead 1791213 Logo
145 people viewed this question
Top Powermatic Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Powermatic Measuring Tool and Sensor Expert? Answer questions, earn points and help others
