Question about Epson RX620 All-In-One InkJet Photo Printer
Epson Nozzle check
When I print a nozzle check on my epson only the bottom half of the pattern is printed. Does this mean the print head is clogged?
  • 1 more comment
  • sandysun Jan 08, 2009
    Morning--Tried the deep cleaning with no result. Any idea how to get the print head out?
  • sandysun Jan 10, 2009
    You must mean below the ink cartridges?
    There are 2 screws below the ink cartridges(where the ink goes into the print head). I removed them and the head did not come out. There must be something else to do?
  • sandysun Jan 14, 2009
    I guess I am a little confused. I removed the print cartridges and where the ink goes into the printer there is 2 screws. If I removed these screws nothing moves. Am I in the right place?
  • 27 Answers
Hi sandysun,
try to deep cleaning at you nozzle from printer software at printer properties..it should help..
if still the same problem...u printhead got problem...try to take out you print head..put in the hot water..becarefull dont wet the chip near the print head
Posted on Jan 08, 2009
  • msaufie Jan 10, 2009
    hiii,
    the print head is above the cartridge..if got any screw there,..un screw it..and take out the print head...
  • msaufie Jan 14, 2009
    hiii...
    unscrew both screw....just take the head out...i have solve this problem b4..
    you can just take the head out..
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back on. Hold down both buttons until the cx4400_ug.1.79.3.jpg On light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Clean the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold down the cx4400_ug.1.80.1.jpg Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Feb 15, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Printer is only printing one color
possible printhead issue. Cartridges maybe outdated too. If you haven't used the printer in a while, the inks on the nozzles will dry out, thus clogging the printhead nozzles. If your cartridges are installed over 6 months now, it may be outdated. Replace cartridges if they are already outdated.
Do a printer check by printing a nozzle check pattern from the printer. To print a nozzle check pattern, turn the printer off. load 10 sheets of regular paper into your printer. hold down the paper button while you turn the printer on, keep on holding down the paper button. let go of the paper button when the powerlight is already blinking. If there are gaps or missing colors on the nozzle check pattern, please do 3 head cleanings. compare the nozzle check pattern over the last printout. If you see improvement on the pattern, continue cleaning the printhead till you get a perfect nozzle check pattern.
If there are no improvements, your printer may need service.
If your printer is not under warranty anymore, log on to support.epson.com. Click on help me find a service center to the bottom right of the page to find epson certified servicers near to your area.
The printer has a one year warranty from the date of purchase. Pls call epson if your unit is still under warranty.
Apr 16, 2009 | Epson Stylus C120 Color Printer InkJet
Epson RX620 yellow lines/blocks on page
Try to print the nozzle check, and see what your out put is like.
If it is not giving you a regular pattern, then have the nozzle
replaced. Most times when the nozzle is clogged with ink, you
get such out-puts. So follow this steps.
How to print the nozzle check:
1. Press the Setup button.
2. Use the arrow buttons to select Nozzle Check, then press the OK button.
3. Confirm the message on the display, then press the OK button to print the Nozzle Check.
Shown below are some examples of what the nozzle check may look like.
Nozzle check pattern with no gaps
Nozzle check pattern with gaps
Apr 14, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Epson Stylus Pro 4800 InkJet (Color printing problems)
If you do a nozzle check...do a cleaning...then do another nozzle check, you can "read" the patterns to see exactly what the problem may be. If the first nozzle check is missing half, then you do the cleaning, and the second is missing half also, check the pattern of the box to see if the missing nozzles are jumping around. If the pattern is exactly the same, you have clogs. If the pattern jumps around, you are having ink starvation issues, and may need dampers.
May 19, 2008 | Epson Stylus Pro 4800 InkJet Printer
Not printing even the test page,full ink ??
I have the same problem, I re-loaded the software, checked all the settings, went through set up procedures and nothing??????? I goes through all the motions, spits out the paper..........blank
Apr 10, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epsom stylus color 460
Hi , i hava same printer like this , the printer need to reset , the counter are exceed the limit number of copies printed so need to reset the printer , you may visit the web site enter the printer number so they wiill able to identified the machine for downloading reseter.
Feb 25, 2008 | Epson Stylus Color 460 InkJet Printer
CX6600 horizontally cuts text
Change the colour of the text to print each colour The same text once in each colour- then you will know what the faulty colour is. Download this utility www.ssclg.com install it and learn to use it. Also go to www.fixyourownprinter.com and take a look At #Epson printers there
Jun 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson RX620 All-In-One InkJet Photo Printer Logo
757 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
