Question about 1995-1997 Chevy Tahoe Ignition Starter Alarm Switch
1997 chevy tahoe misfiring 5 and7.
I have a 1997 chevy tahoe misfiring on 5 and 7 cylinder. changed everythind from a tune up to the ignition and the computer. still having the problem. please help.
  • Anonymous Feb 27, 2009
    My 1996 chevy tahoe shows a misfire on cylinder one everyone said it the injector ,Everyone being my half *** friends lol but it is costly 2 change the injectors ,should I change all or just one please help thanks code p0301
    Problem Solver:
  • 5 Answers
Check your FUEL INJECTOR HOUSING. The old style factory housing most likely has an internal crack. OLD style has the INJECTORS AT THE HOUSING with tubes running fuel to the engine. NEW housing has wires running to the INJECTORS AT THE ENGINE. If you have the OLD style then it is probably (99%) cracked. This will cause fuel to be sprayed into neighboring cylinders causing a firing problem. This crack IS NOT visible because it is internal. After exhausting all the regular solutions to your misfire with no success, you will probably try to replace the individual injector (like I did....cost approx. $300) and you will still have the misfire. To replace the entire housing with injectors will cost around $400. Good Luck.....on other forums, I've seen people replace anything and everything (including engines) and still had problems with the misfire.
If you're in Louisville KY and need a mechanic (not a parts replacer) for this, try Tony Johnson @ 3215 Fern Valley Rd. 502-387-0847
Posted on Sep 20, 2012
  • janet prigden Mar 06, 2013
    i have put a new housing on it thanks
    New Friend:
Mmine showed the same thing and it ended up being the fuel pressure reregulator leaking into #5 and #7 ports. it's directly attatched to the ininjectors under the intake plenum
Posted on Jan 28, 2013
    i will look at that thank u
SAME THING HAPPING TO ME!!! changed every thing and any thing... iam up to $800.00 this sucks. its giving my truck a bad name! but who cares chevy ROCKS!!!
Posted on Sep 20, 2011
I had a 1995 tahoe that did the same thing.. turned out to be a blown head gasket ! it is probably spark knocking also !
Posted on Nov 03, 2009
    all that isnew thanks
    Problem Solver:
  • 14 Answers
Change you spark plug wires
Posted on Jun 21, 2009
  • 87 Answers
#5 and #7 are easily confused because they are right next to each other in the firing order of 1-8-4-3-6-5-7-2 , you should have a flat style cap . check to see if the wires are crossed !!
Posted on Jan 02, 2009
    i have done that like 10 times thanks
Why is my 1999 Chevy Tahoe backfiring?
Hi Dion:
When under acceleration, an engine experiences increased cylinder pressures. If you have a spark plug(s) that is in poor condition, it can misfire (or not fire) then, so the unburned fuel will ignite in the exhaust, and "backfire".
Another possible cause could be that the timing is not retarding when the vacuum drops under acceleration.
My recommendation?
TIME FOR A TUNE UP
Cheerfuls.
Aug 08, 2015 | Cars & Trucks
Misfire in cylinder4 97 tahoe
Check the plug and wire by taking them out and swapping them with a plug and wire from another cylinder. If the miss follows the parts, they are bad. If the miss stays with the cyl you may have a bad injector, bad compression or bad dist cap.
Mar 19, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
1997 Chevy Tahoe muti misfire and smell of gas
try to change the rotor and the distributor cap and the high tension wire.
Dec 07, 2012 | 1996 Chevrolet Tahoe
My 97 tahoe only running on 6 cylinders
If compression test is good is either no spark, bad coil or wire, or no fuel, bad fuel injector. Need to clarify which is not functioning properly.
Jun 23, 2010 | 1997 Chevrolet Tahoe
Ignition cylinder stuck in on position. how do you change it if it won't move?
if your shift selector cable broke/came loose, the vehicle will still think you are in gear and will not allow you to lock the column and remove the key. easiest way to see the cable is to remove the instrument cluster and look behind the orange "PNRD21" indicator.
Feb 21, 2010 | 1995-1997 Chevy Tahoe Ignition Starter...
97 Chevy Tahoe, bought used, not sure type Trans, diagnostic code
Number 5 cylinder may have clogged fuel injector. O2 sensor can be replaced on exhaust pipe. EGR valve can also be replaced. good luck
Apr 27, 2009 | 1997 Chevrolet Tahoe
200 Chevy Tahoe 5.7L
Do you have any engines codes like P 0300. Sounds like ignition coils ,check input wires to coils if okay replace both coils.I have seen this few times
Apr 12, 2009 | 1999 Chevrolet C2500
96 bmw 740il misfire
This is a pretty common problem. I would change your valve cover gaskets. They run around ~ 50 bucks. If they are bad it will leak oil into spark plug well and cause a misfire. Very known on the 740.. Also if tune was not anytime not too long ago id change spark plugs while you at it. Then clear the computer and if you still get misfire on 8 try changing the ignition coil which is right about the cylinder with cylinder ignition coil 5. clear the computer. if you get random misfire and misfire cyclinder 5 after then its your ignition coil. parts store runs around 100 bucks
Dec 22, 2008 | 2005 Hyundai Santa Fe
1995-1997 Chevy Tahoe Ignition Starter Alarm Switch Logo
1,309 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
