Question about Onkyo HTR500 Receiver
No sound produced from various listening mode. However when in direct mode sound produced from front speakers only. Speaker configuration is set to 5ch.
    Genius:
  • 1,175 Answers
Hi...
I dont have really good news. It's the DSP board assembly that's not working.
Get in touch with unitedradio.com and see what the cost is on a new assby.
Posted on Jan 02, 2009
Why have 3 out of 5 speakers on my PC stopped producing sound even after configuring and updating drivers??
Sounds like a configuration problem. See this... http://www.logitech.com/en-us/support/224
Also, visit Control Panel/Sound, select your Default Device, and click "Configure" to verify that the configuration is set correctly.
Jul 15, 2014 | Logitech Z-5500 Speaker System Control...
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Onkyo TX-SR309 - Sound output only from 2 speakers from five. Hi, I have a Onlyo TX-SR309 receiver connected to a Wharefedale MS100HCP speaker package. It was working fine for 15 months but now the...
Some info from the manual:
The Dolby Digital and DTS listening modes can only be selected if your Blu-ray Disc/DVD player is connected to
the AV receiver with a digital audio connection (coaxial,
optical, or HDMI).
• The listening modes you can select depends on the format of the input signal. To check the format, see "Displaying Source Information"
• While a pair of headphones is connected, you can select the following listening modes: Mono, Direct, and Stereo.
• While Speakers A and B are on, you can select only the
Direct, Stereo, Mono, or T-D (Theater-Dimensional) listening mode.
Plus this Bit of info on the speakers A and B buttons.
While Speakers B is on, channels are reduced to 2.1 in the
main room.
If you can access the speaker configuration it should provide test tones to each speaker. If you can't the speaker A and B are not set right.
If you have pressed the stereo or mono button no sound will be heard except from the front two or the sub.
Sep 01, 2017 | Onkyo Audio Players & Recorders
I have a Onyko TX-SR303 5.1 Receiver and sound is only coming out of left front speaker.
Could be the IC that controls the various sound/surround channel modes. Had that happen on my Pioneer receiver.
Charged me close to 200 bucks to fix!
Aug 24, 2017 | Onkyo TX-SR303 Receiver
Intel(R) Desktop Board D945GCL,Window 7 ultimate is installed.After installing Audio Driver (Version 5.10.5208.0) Sigma High Defination Codec,in speaker properties,Jack is showing Jack information not...
Please ensure that your bios setting is enabled for audio.
1. Have you installed the correct windows 7 driver or have you configured with the vista driver?
2. If you have installed with windows 7 driver, check it for 32 bit or 64 bit and you are installed perfectly!
3. Check the windows service. Go to "run", type "services.msc" and press enter. In that opened window, direct to "windows audio". Open it and check the service is started or not. Also ensure that the startup type is set to be "automatic".
Hoping you will be short out!
Aug 19, 2011 | Intel D945GCL Motherboard
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
There are many different "listening modes" integrated on my Kenwood VR-7070 6.1 channel receiver. But i only get both front speakers to work when in "mono" mode. Is there an easy fix?
There is not a "fix" for this selection, MONO is basically a single channel output so there is no seperation for various speakers like left or right which is a stereo effect, mono is like a single speaker sound so you are fortunate to have the sound from 2 speakers but they deliver the same sound.
Jun 10, 2010 | Kenwood VR-7070 Receiver
Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
Mar 25, 2009 | Computers & Internet
Can not get 3 speakers on my samsung home theater to work!
There are a few settings that will just give you a stereo output. The first one is with the Pro Logic II. If you press the PLII Mode button on the remote it will go through a series of settings from MUSIC ➞ CINEMA ➞ PRO LOGIC ➞ MATRIX ➞STEREO ➞ MUSIC. Pro Logic setting will only produce sound from the front speakers and Stereo from the front speakers and the sub. Put it on Matrix for 5.1 surround sound.
Also for speaker settings follow the instructions below.
Signal outputs and frequency responses from the speakers will automatically be adjusted according to your speaker configuration and whether certain speakers are used or not.
In Stop mode, press the MENU button.
Press the Cursor down button to move to Audio and then press the ENTER button.
In the SPEAKER SETUP, press the ENTER button again.
Press the Cursor button to move to the desired speaker and then press the ENTER button.
For C, SL, and SR, each time the button is pressed, the mode switches alternately as follows : SMALL ➞ NONE.
For L and R, the mode is set to SMALL.
SMALL : Select this when using the speakers.
NONE : Select this when no speaker is connected.
Press the RETURN button to return to the previous level.
Press the EXIT button to exit the setup screen.
It also seems that with this system, if you are on 5.1 surround but your music source is only in stereo, you will only hear stereo.
Nov 20, 2008 | Samsung HT-Z310T Theater System
My Onkyo TX SV 535 Surround Sound wont work
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
Onkyo HTR500 Receiver Logo
55 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
