Question about Brother HL-2040 Laser Printer
"printer not responding" message
New machine, replacing one that was identical but old. I accidentally damaaged the old machine. New machine is hooked up, I checked all connections, even made sure the USB went directly into the computer (rather than hub). Using Macintosh system 10.4. The Mac will print fine on my connected Canon. I used the same connection and USB cable to hook to the HP. Still get "printer not responding." None of the idiot lights go on. The only light that goes on is "green" (as in "good"). The "test page" comes out fine. I can't think of anything else to try. It's the same printer driver as I've had - from either Brother or included in the Mac OS software. I'm using a dual (motorola) processor 2.5 G Macintosh with 2 gigs of RAM, and not having any other problems. (Over 100 gigs free space on hard disk.) Very frustrated. Thanks.
Try a diferent wire
Posted on May 06, 2007
Why is it that wireless printing using same hardware and service provider will no longer work at new address and SP account?
When you say :"identical" do you mean the same unit, or another unit of the same model? I experienced the same issue after moving, with a new "identical" model modem/router provided by the ISP. Until the provider replaced the router with another "identical" one I couldn't get the wireless printer (HP in my case) to connect no matter what I did either using the WPS function or entering my network settings manually. Other wireless devices worked okay.
Sep 09, 2014 | Canon MG3170 INKJET COLOR ALL-IN-ONE...
Intellifax 2800 does not register new drum. I put in new drum and it is extremely light copies and is stll telling me to replace drum soon
If you replaced the drum with a new one, then a special plastic piece with slots in it will be ejected. This will reset the "Replace Drum" message. Now the light print is probably due to the toner needing replacing. When you put in a new drum, it needs new toner too. Unfortunately, most people replace the toner into the old drum, which does no good and becomes wasted. NEW DRUM NEW TONER. Now if you have replaced the old drum with another old drum, you won't get the reset done properly and the new drum won't load any toner either. Perhaps you accidentally removed the plastic sheet when you replaced the drum? Well then, find the piece and run it through the paper feed, it will then reset. Best of luck
Oct 06, 2010 | Brother IntelliFAX 2800 Laser Fax
I put a tesco brand identical cartridge into my Lexmark 5600 and a message said that the cartridge was not compatible with my printer. As i said the new cartridge was identical to the old one. Please help.
Unfortunately, the printer manufacturers want to make money selling cartridges. So they add little things that tell the printer if this is a genuine cartridge from the manufacturer. The alternate brands can not always keep up with this coding. Before you give up, try reseating the new cartridge. Otherwise, try the manufacturer's exact replacement cartridge.
I wish that I could be of more help.
Apr 24, 2010 | Epson Stylus 2200 InkJet Photo Printer
Printer not responding
I had the same problem after I accidentally pulled the power cord out of the printer - it turned out to be the firewall on my PC, when the printer reconnected to the wireless network it got a new IP address and the firewall was blocking incoming messages from it.
Jun 13, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Cartridge not detected or missing message.
did you remove the tape from the new cartridge ?
Dec 23, 2008 | HP PhotoSmart C4280 Laser Printer
Tv not responding to new remote control
Was the replacement remote identical to the original one; or, does it need to be programmed. Also, if your replaced your old remote because it was not working, it might be that the IR sensor on your TV is bad.
Nov 04, 2008 | Aiwa VX-S205 Combo
Star SP 2000 Printer
Make sure the dip switches are set identical on each printer. Use your old printer as the example They are located at the bottom of the printer near where the interface cable plugs into the printer.
Oct 29, 2008 | Star Micronics SP 2000 Matrix Printer
I think I killed my HP L7580 printer... Powers up, but does not respond
hello..
Not neccesarily.. the voltages are different for each printers power supply. is it a power cable with a little black box on it? or just a straight power cable to the wall?
The 2510 may have a diferent voltage.. you can tell by looking on the bottom of the black box and see what the OUTPUT is.. is they're different.. time to go shopping
Best Wishes
Sep 25, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
New ink cartridge problem
pleaz change the same original cartridges
Apr 19, 2007 | HP OfficeJet V40xi InkJet Printer
Brother HL-2040 Laser Printer Logo
225 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
