Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP-511HW40 fleshing with green color and shuts off
When I turned on my 6 years old Sony KP-511HW40
from cold, it works for about 5 minutes and then the screen
fleshes with light green,shuts off and then switches off.
Red stand-by light flashes continuously. Is it lamp or tube issues?
Please help.
  • 2 more comments
  • souksanh926 Jan 02, 2009
    Thank you much... I will follow your instruction to see if it fixes. Happy New Year 2009!
  • souksanh926 Jan 03, 2009
    After following your instructions... The set seems to be working great for 3 hrs so far... Thank you very much and Best wishes...
  • jcorral Jan 07, 2009
    fleshes with red light,shuts off and then switches off.
    Please help.
  • souksanh926 Jan 10, 2009
    I have the same problem again after 3 days I follow the instructions. Please advise what to do next. Thanks in advance...
    Souk
  • 185 Answers
This is a common fault adjust the little black box in front behind the small wooden cover. you will see 6 controls don't adjust any of the top 3 only the bottom knobs 1 for each color. slowly back the control counterclockwise turn the set on and wait untill it shows a picture, slowly adjust the control for the color in question utill the color balance is correct- black and white with the color setting turned down all the way with the user menu when balance is ok you are all set.. turn the color back up with user control. rtepeat process if needed.
Posted on Dec 26, 2008
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
Sony KP-511HW40 - blue/green tint issue - convergence issue?
Replace your convergence ICs STKs big black ics Go by number on them STK392-560 ect..... Parts you can order on line www.electronix.com or Call 1-800-223-3205 you will also need silicon heat sink compound to put on New ICs replace Both STKs
Dec 25, 2008 | Sony KP-51HW40 51" Rear Projection...
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57HW40
Have a Tech. replace the focus/screen block if the problem continues you have a bad red CRT.
Sep 21, 2007 | Sony KP-57WS500 57" Rear Projection...
Green screen...
Probable bad green CRT..........usually about 600.00....T.
Aug 04, 2007 | Sony KP-57HW40 57" Rear Projection...
The dark colos have a lil' green on them...why?
How old is this set? Sounds like a CRT issue, might be able to adjust the G2 control (SCREEN), you will have to pull the bottom pannel off the front and there should be another little 1/4" thick board that comes off with a few screws and then a 6 knob control, turn your color all the way off in the menu and adjust your screen controlls up till you get some overcolor with lines in it and then back down just before the lines (MAKE SURE YOU DEFAULT ALL YOUR USER MENUS) check that you have a black and white picture after adjusting all 3 screen controls like before with the menu color off. If you have a bad CRT it will go again, the CRT may no longer be available, if the set is not too old i.e. 5-8 years old it may be a defect with multiple CRTs.
May 22, 2007 | Sony KP-53HS30 53" Rear Projection...
Rear projection tv flickers green/shuts off
rodman, i just started having the exact same thing on my Sony (same model). it's about 5 years old. did you ever find a solution?
Dec 10, 2006 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
146 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
