Question about Logitech Z-5300 Computer Speakers
Is it possible to hook this system to my DVD
I do not want to hook the system to my computer but would rather have it hooked to my DVD or big screen TV. Is this possible? If so, what kind of cables do I need? Thank for any help... JR
  • JoAnn Renshaw Apr 18, 2007
    The ends of the cables are not the correct kind to fit in the DVD or TV. Can I purchase a cable to convert the cable to fit?
    Problem Solver:
  • 14 Answers
If you have RCA outputs on the Logitech Z-5300 then just plug the rca leads into your video or tv's audio out's
Posted on Apr 18, 2007
Can i hook up my rca dvd home theater system to my tv so i can get sound from watching tv channels which is hooked up to dish satellite? is this possible?
Yes it is possible.
All you need to do is run a cable from the Audio Out on your TV to the Audio In of the DVD.
Then you will be able to get the sound of TV channels from the DVD speakers.
Mar 10, 2011 | RCA RTD317 Theater System
Hello how do i hook up a DVD player to a 2002 big screen tv
Seasons Greetings
hook the cable wires to the DVD (its easy color coded) first... now look on the back of TV for A/V panel this is where you are connecting to... now get a DVD place in player and press play and also using the TV remote switch to AV.....
Dec 19, 2010 | Televison & Video
Tried to hook up a playstation2 and didnt hit
try checking the video connector on the PS2. Make sure its firmly seated
Nov 24, 2009 | Cyberhome DVR 1600 DVD Recorder
I'm trying to hook up a 5-speaker Dolby surround
out of tv, into the combo, out of the combo into the surround amp and this work
Sep 01, 2009 | Televison & Video
I can't seem to get my dvd player to play on screen
Set the TV to look for a signal on the same input your are hooking your dvd player to. Example, if your dvd is hooked to video 1, set the TV to show video 1 on the screen.
Dec 31, 2008 | Dell Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Hooking my tv to the bose
u wann hook up this unit so it plays muci throw biiggger bos system > doesnt big system have cd player this cd only not tv dvd unless it says dvd now then use outputs on back to tv input but i think it only cds
Feb 02, 2008 | Bose Wave Radio
DWM-3500
consult your tv manual, if your tv have a "speaker out" on the back then you can hookup your speaker directly but if your tv only have an "audio out" you can only hook this up to "audio in" of your audio system.
Dec 22, 2007 | Sanyo DWM-3500 System
Dual Screen not working
I`M TRYING TO HOOK UP THE OTHER SCREEN THE DVD PLAYER PLAYS FINE BUT I CANT HOOK UP THE OTHER SCREEN TO IT HOW DO I HOOK IT UP
Aug 13, 2007 | Power Voice System Venturer PVS1988...
Can the cable ends be converted to fit a DVD?
You can certainly purchase a cable or an adaptor to connect the speakers to almost anything - this however is not the issue - z5300 computer speakers have an impedance of 8 ohms, whereas most home theatre systems will be set up to use speakers with an impedance of 4 Ohms or 6 ohms or 8 ohms - using the wrong type in the wrong configuration is very likely to result in damage. Also the speakers contain their own amplifier, and are designed to accept an input that has not been amplified to speaker levels before - most tv/dvd audio output will be amplified, depending on the model, so will almost certainly destroy your speakers unless you have a low amplification output on your tv/dvd. If you post back with the make and model of your tv and dvd player, hopefully i can find the necessary info to describe how you could make the connection if it is possible. Logitech says; "Logitech speakers are powered speakers and are designed to be used with a home computer. However, it is still possible to connect your speakers to many other devices. You can connect any Logitech speaker to any device that has a pre-amp mini-headphone jack. Home amplifiers will normally contain a standard ¼" headphone jack. You'll need to purchase a ¼" to 1/8th" adapter to connect your Logitech speakers to a home amplifier. Note: Under no circumstances should you connect your Logitech speaker system to an amplified output such as the rear outputs of a home amplifier. Doing so may cause damage to your Logitech speakers as well as your home amplifier." Hope this helps - please post back with details :)
Apr 19, 2007 | Logitech Z-5300 Computer Speakers
Logitech Z-5300 Computer Speakers Logo
250 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
