Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Canon power shot S400
LCD screen as lines on it and affects the actual picture-- flickering white lines
Eric
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Dec 28, 2008
Tv problem troubleshooting screen all white no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | LG Televison & Video
I am unable to shoot Pictures and the screen shows complete white after Shots
you need change a lcd screen,some lcd screen is easy to broken or black. it affects the function and beatuty of the picture.
http://www.digitalcamera-parts.net/
www.skiliwah.cn/
msn/e-mail:e-8090team@hotmail.com
cindy
Oct 05, 2011 | Canon PowerShot A470 Digital Camera
A85 camera LCD shows up with pink and black lines every time a picture is taken. LCD screen displays the camera icons on LCD screen but will not take anymore photo's. Lens used to view picture status...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 06, 2010 | Canon PowerShot A85 Digital Camera
LCD picture veiw is runny like a runny film
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Oct 14, 2009 | Canon PowerShot A75 Digital Camera
Canon PShot A85 - blank screen with a flickering purple backgr
Definitely sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Jan 16, 2009 | Canon PowerShot A75 Digital Camera
Flickering screen
Purple streaks, lines and casts across the recorded images are some of the first stages of CCD failure. A blank image will occur when the CCD completely fails. A blank image however is not to be confused with a blank LCD (998bills) where images are recorded OK but nothing is visible on the back, that fault requires the LCD to be replaced by a service centre. As for CCD's, this is a known fault and will most likely be repaired at no charge by Canon if taken directly to them. More detailed information about the CCD problem can be found on the website of your local Canon, as an example, Canon Australia have this page http://www.canon.com.au/support/customer/default.asp?DXI=KnowledgeBase/Customer/KBArticleForm&File=KB01634&productID=powershota80
Dec 25, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
PowerShot S60: Purple Bar on LCD viewer Screen:
This sounds like it might be impending failure of the CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Oct 17, 2008 | Canon PowerShot S60 Digital Camera
Image on LCD jumps
Apr 09, 2008 | Canon PowerShot A95 Digital Camera
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Flickering lines and the color is off
I found the same problem recently, but it is intemittent. It then changed from flickering lines to more of a blurred picture on the LED screen. I have tried all things to clear it, but the best seems to be to turn it off for a while and it often clears. Previously captured pictures review fine on the LED screen, but when the screen blurs (with a blurry motion too!) that is how the picture records and reviews. I bought my Ixus 400 in Sep 03 and this problem started in Jun 07.
Aug 14, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
90 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
