Question about Teac AG-D8900 Receiver
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to receiver seems ok? I can't seem to find any fuses on the sub woofer. Is there some place I should be looking? Thanks!
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Posted on Apr 16, 2009
2 Suggested Answers
SOURCE: teac AG D8900 II sub woofer not working
click on the blue "teac sub woofer" link top of page, solution is in my response to another with same problem-that is at least 3 of us with this now.
JS
I wish to replace a subwoofer on a surround sound system
In most surround sound systems the sub woofer is powered separately and uses a standard RCA coax connection to the receiver/amplifier.
Replacing is simply plugging in the new and reconnecting the coax cable.
Usually the audio signal is Dolby Digital 5.1 the (.1) is the LFE Sub-woofer. The connection is between the Subwoofer RCA connector on the amplifier and connects to the (LFE-Line) in on the subwoofer speaker.
Hope this helps?
Aug 09, 2016 | Audio Players & Recorders
No sub woofer volume
Make sure Subwoofer power is on and connected with RCA cable in correct place.
Go into setup of "Speaker setup" and select 5.1 setup. Activate subwoofer to YES if setting is No.
On some Amps you need to select front speakers to SMALL even if you have large speakers to enabled subwoofer.
Sep 08, 2014 | Yamaha RX-V375 5.1 Channel Home Theater...
Can I connect an active speaker to the Teac AG d7900 output
http://produto.mercadolivre.com.br/MLB-184407791-av-digital-home-theater-receiver-teac-ag-d7900-_JM
It would have helped to know something morwe about the 'active' speaker.I imagine its manual would tell you what it needs for input.
Active speakers are usually designed to be driven by volume-controlled Line Level inputs. This receiver has none except for the Subwoofer PRE Output.
Aug 17, 2011 | Teac AG-D7900 Receiver
Can I hook a turntable to a Teac AG-D8900. Where do I input?
only if the unit has a PHONO input never plug a turntable into any other jack as teh voltage is different.
I have seen an adapter so that you can plug a turntable into an ordinary input I believe Radio Shack but that was along time ago try ebay
Jan 08, 2010 | Teac AG-D8900 Receiver
Teac AG D8900 II sub woofer not working
JS
Dec 26, 2008 | Teac AG-D8900 Receiver
TEAC DIGITAL HOME RECEIVER AGD 8900 AV
I changed the diodos from power supply.
I thought that help you offered
was free,but I forget that nothing here is free.
Thank you anyway
Dec 15, 2008 | Teac AG-D8900 Receiver
Subwoofer
cheak all setting woof out ect cheak wires cheak for i pod updates
Feb 01, 2008 | Teac AG-D8900 Receiver
Teac AG- D8900
Stereo Tech: Check speaker switch(A or B) also be sure you have selected FM, AM, Video, CD ect., somtimes if you do not have a stereo signal the unit will mute best to fist try tape or CD input. Hope I helped good luck.
Nov 27, 2007 | Teac AG-D8900 Receiver
Power comes on but speakers do not make noise
Stereo Tech: yes their is a fuse inside that possibly opened, but does the unit show PROTECT across the display? if not you may have goten lucky and just did a fuse small PC board just behind the transformer. Good Luck
Jan 14, 2007 | Teac AG-D8900 Receiver
Setting Up The System
You can find the requested details at: http://www.teac.com.au/file/product_manual_408.pdf
Mar 09, 2006 | Teac AG-D8900 Receiver
Teac AG-D8900 Receiver Logo
348 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
