Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Wega 32"TV - noise on startup
I have just purchased a Sony Wega 32" TV. Although working well so far when I initially turn the TV on there is a slight flash on the screen, which remains black for a while, and then a strange noise before the picture appears a few seconds later. Is this normal??
    President:
  • 1,284 Answers
The slight flash on the screen is usually because the CRT (picture tube) is holding a better than average charge and this is what we call "pre-glow" The noise that you hear, is that everytime you turn it on or just after it has been off for a while? If only after the set has been sitting off for a while then your noise is the internal degauser for the CRT and that noise is 100% normal. The degausers in Sony TV's are so strong they usually make the plastic cabinet vibrate a bit.
Posted on Apr 18, 2007
What is the life span for the Sony Wega KV-32HS510?
10,000 continous woking hours is calculated to most of the CRT based TVs.
It is only calculation, but the life span might be much more that that. I've repaired a Sony TV recently, which was released by Sony Corporation Japan. The model is KV1820, an 18" Trinitron TV, still works perfectly. Just see, it is an '80 model one.
Jul 31, 2014 | Sony FD Trinitron WEGA KV-32HS510 32" TV
32 inch sony trinitron wega
It will most probably need an overhual of the power supply
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Wont turn on
The problem is with its main power regulator section itself. Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
This is the fault, and check points. For more details about the blinking codes for Sony TVs, check this.
Jan 04, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Bravia BX300 Engine 3 and its Demo mode is always on (even if I press RETURN button to exit demo mode). How could I turn it off permanently???
you should restore the factory settings to do this
  • Turn on the TV.
  • While holding down <up arrow> button on the remote control, press POWER on the TV. (The TV will turn itself off, then back on again.)
    Release <up arrow>
  • IMPORTANT: The reset will clear all of your customized settings
    including the Parental Lock setting.
  • initial setup run automatically
  • if you have doubts on initial setup download this pdf
Jun 14, 2010 | Televison & Video
Sony tv will not turn on
the power supply is a switched mode. you need to take your tv to a w/shop, and let them check the following.
powersupply rectifier diodes, power trasistor lekage,
diodes, zener diodes,
if a 90-110 volts to the line trasistor,
a line transistor be checked.
the tv simple problem
Mar 29, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
SONY TV
how many times the led blinks?
Jul 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV 32HS420 SONY WEGA TRINITRON
Shorted diod D503 next to HOT on main board
Apr 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega reduced sound
the problem maybe is in the sound IC. try to re solder the sound section of the TV.
Apr 13, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Grand Wega 50" LCD
What is model no of your tv, I think, there maybe a modification for it
capital98
Nov 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 32" wega tube
plug out tv and start over by then the tv will reset itself.if that does not work call in a tech to solve,your problem.good luck/
Apr 01, 2007 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
153 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
