Question about Olympus Camedia C-3030 Zoom Digital Camera
I am looking for an online manual for my C-3030 Olympus
I must have inadvertently changed a setting during a photo op session, as the pictures all of a sudden looked very grainy and the contrast was very bright in the viewfinder screen. I would like to know all the functions and settings of the camera. Thanks
    President:
  • 379 Answers
Http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=521
here is link to Olympus manual for the C-3030 zoom.
fixya.
Posted on Dec 26, 2008
When i take pictures they show with a pink color? i reset the camera to factory settings but still same pink pics advise?
This FE-340 Olympus is a great camera. Lots of features and usually great results
  • Indoor pictures with flash set on auto WB (white balance) should not be a problem
  • Indoor pictures without flash requires setting the WB to match the light source in the room (incandescent, florescent etc) Outdoor pictures WB on auto generally not a problem
For more help Include a photo with the metadata of the photo from the image data file
Dec 02, 2015 | Olympus FE-340 Digital Camera
Can not download from Olympus 3030 to MAC BOOK PRO
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Dec 20, 2012 | Olympus Camedia C-3030 Zoom Digital Camera
I need windows 7 driver for olympus c-3030 photo camera,where can I find it?
Consider NOT using a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Mar 17, 2011 | Olympus Camedia C-3030 Zoom Digital Camera
Install disk says that op system, windows 7, does
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 28, 2010 | NetGear WGR614L Wireless Router...
Pixel problem, all pictures taken have poor pixel resolution
It sounds like you set the file settings to a small file size - perhaps in order to get more photos on a single memory card. You need to change the setting to the largest file size possible, at the highest quality. The steps for this will be in your manual. If you need detailed instructions and don't have your manual, let me know and I'll lookup your manual online.
Dec 30, 2008 | Olympus Stylus 600 Digital Camera
I am getting a lot pre-flashes before take the photo
In your manual look up page 49 AF illuminator change the setting to off and then you rprblem will go away I have had this camera for ages and couldn't figure heaps out this was so easy to fix yet so hard to find the answer. I am also finding that the photo that I see throught the lense is good and nice colour until I put the shuter button down and the photo changes colour then are you having the same problem?
Dec 23, 2008 | Olympus EVOLT E-410 Digital Camera
Many colors appear
I don't know the C-720 specifically but many Olympus digicams have special effect settings and you may have inadvertently switched one of them on. If you have the manual, look through that for information on where in the camera menu such settings are found & then check them. Failing that, there is a menu item to reset the camera to Factory Defaults - see if that helps.
Oct 11, 2007 | Olympus Camedia C-720 Ultra Zoom Digital...
Camera will take picture, but when viewed they are a strange colour.
This sounds like the first signs of CCD sensor malfunction. If this is correct it will get worse and pretty shortly you will have no image at all in capture mode. Have a new sensor installed and camera will work fine.( btw this is a common fault effecting all makes of digital cameras and v-cams ).
Aug 20, 2007 | Olympus FE-170 Digital Camera
Time & Date Stamp
The date and time (and a lot more) are stored with every image. Any photo printing program should have an option for printing the date and time on the picture (or in the margin or even on the back if the printer is two-sided).
Jul 07, 2007 | Olympus Camedia C-3030 Zoom Digital Camera
High Flash Resolution
You are shooting with the exposure bias set too far on the plus side, not familiar with the 550, do You have the user manual? If You look at exif data of posted photos, You will see that many are taken at settings below the midpoint. If You don't have a manual, go to the Olympus website, many manuals are available for download. You may also find the function in the menu based on sunny, cloudy, etc, this is important to set right
Sep 12, 2005 | Olympus Camedia D-550 Zoom Digital Camera
Olympus Camedia C-3030 Zoom Digital Camera Logo
121 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
