Question about Panasonic Lumix DMC-FX8 Digital Camera
Clock setting not saving
I have just bought this camera but I cannot seem to get the clock to save. Every time i turn the camera on it asks me to set the clock. Sometimes the clock even resets when the camera is turned on. I am certain I am following the instructions correctly in setting the clock. This problem is very annoying as i do not want to have to return camera. I would be very grateful for any solutions somebody can give me...
  • 944 Answers
This link will give you the user instruction manual for your camera; http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportModel?displayTab=R&surfModel=DMC-FX8K&modelNo=DMC-FX8K&storeId=15001&catalogId=11017&itemId=94211&displayServiceCenter=false# Page 19 describes the clock setting procedure - first check that you are doing everything as described, especially the "press menu button 2 times after finishing the setting" If you still have no luck, then unfortunately there is a problem with the internal clock/settings battery/cell, which should normally charge from the main battery enough for 3 months - on this camera, the internal battery is not a user replaceable item, but your warranty should allow you to get it replaced free. Sorry if bad news, hope it helps :)
Posted on Apr 18, 2007
Synergy global supply model 9105 how to set
http://www.synergythesource.com/doc/alarm-clock-setup-910500.pdf
Quick Setup
Model 9105
Alarm Clock Radio
1) Plug clock in before making any adjustments.
2) If using on East Coast- Do nothing! Time and date are set to EST- Daylight Savings time is 'On". Clock is ready to use.
3) If using in time zones other than EST. Hold the clock with LCD facing you. Lean clock back and find small button on bottom right marked P-M-C-E. Hold for 2+ sec. LCD will blink the time zone. Press button again until LCD blinks the correct time zone, CST, MNT, PACIFIC.
4) Daylight Savings time- Default is always on. If you are in a zone that does not recognize daylight savings time. Hold the clock facing you, lean clock back and on bottom left is a small button marked D. Hold 2+ seconds and the LCD will blink ON. Press again and LCD will blink OFF. Daylight savings time is now OFF.
5) If power goes out, clock will retain time and alarm will sound if in the ON position.
6) Replace batteries once every year...!
7) If clock looses time or date:
a. Hold Volume +, and Tuner + at same time for 3 seconds
b. Clock face will blink year
c. Turn outer ring of alarm to set Year
d. Press Tuner + once, turn outer ring to set Month
e. Press Tuner + once, set Day
f. Press Tuner +, set Hour
g. Press Tuner +, set Min.
h. Press Tuner + to save all settings.
You must go through all set points to have them remain in memory. (have to run thru all a - h, can't set just Day or Hour/Min, etc. without starting with Year)
Any questions please call:
Synergy Global Supply
804 435-7520
8:00am-4:00pm EST
Oct 23, 2012 | Audio Players & Recorders
Tip
Setting time with your JVC VIDEO CAM.
Sometimes we are lazy enough to read our users manual, we want it easy and quicky. For this reason this is common issue to JVC camera users find hard on setting their camera's clock and calendar. Setting is easy but saving your setting is tricky. So set your camera's date and time the usual way and make sure to switch off your camera first completely and remove power(battery or ac adapter) to have your setting save. Next time it will not ask you to set again until internal clock battery expires.
on Mar 01, 2010 | Cameras
I can not set the clock on my i river reader it keeps going back an hour after i set it help please
Do you have your PC set to automatically adjust for daylight savings? If so, try turning that off and setting your clock forward one hour manually. Although it seems that this would cause your clock to be one hour behind if the setting software isn't adjusting the clock setting for savings time.
May 03, 2011 | Computers & Internet
Cybershot will not store clock settings
Hi!
The internal battery is bad. It has to be replaced. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Jul 06, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
To check the clock, press CLOCK.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Sharp Atomic Clock Daylight Savings
I have misplaced the manual for my sharp Atomic clock, need to reset the time zone and shut off the alarm. How can I obtain a new manual?
Mar 10, 2008 | Baby Gear
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Panasonic Lumix DMC-FX8 Digital Camera Logo
155 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
