Question about Motorola Mobility H700 Wireless Headset
Phone wont detect bluetooth H700
About a week ago i bought myself a h700 Motorola blue tooth for my new cellphone. When i first got it i set it up to the phone and everything was working just fine. Yesterday I had to charge the blue tooth and once it was done charging i started having some problems with it. I pressed the button so i could call someone but all it would make is a beep sound and that was it. From what i could tell it wasn't connecting to my cellphone so i removed the device and now its not letting me put it back on the phone. When i put the blue tooth in discover mode the cellphone will search for it obviously and then a screen will pop up saying that it cant detect the device. Why cant it detect the device when i have the blue tooth in discover mode?
  • 5 more comments
  • Anonymous Dec 11, 2007
    cant connect bluetooth to my blackberry pearl
  • Anonymous Dec 12, 2007
    phone wont connect
  • Stett Dec 15, 2007
    Sounds like the same as reported by others. When i get the phone, a Treo, the setup went fine. Then after recharging the H700 it would not sych anymore. I have tried to synch with phone on and off nad headset on and off. Nothing works.
  • tatita Apr 07, 2008
    same ting
  • Anonymous Apr 08, 2008
    H700 Bluetooth was working fine for a couple of weeks now it says on my Motorola Razor unable to connect I have turned on the bluetooth till it turns purple open the boom go to fine devise it says 1 click on motorola h700 and it seems it finds it then it it says can not connect
  • Anonymous Jan 10, 2009
    motorola h700
  • Anonymous Mar 18, 2014
    my mtoroa Hz720 Elite Flip Bluetooth is not picking up calls when I push the button
Mine could be discovered when powered off/ on my cellphone and retried... Sounds like solution to M$ programs, eh? :)
Posted on Apr 20, 2007
My motorola h700 won't turn purple to connect to my motorola i576
Make sure the battery is good in your H700.Make sure your Bluetooth is enabled on your i576. To do this, go to Contacts>More>Bluetooth>Setup>Power> then select On. Back up one level and select Link To Devices. If everything is correct, they will find each other.
Dec 20, 2009 | Motorola Mobility H700 Wireless Headset
Changed phones want to install blue tooth h700 but it asks for a passkey. Where do I fibnd the passkey?
The passkey is 0000 (four zeros). If you need instructions do the following:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} First off, you want to have the H700 fully charged up and it's probably good to have the PHONE fully charged up too. Now turn off the H700 (the ring around the talk button should not be flashing blue every few seconds) then push the talk button for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the PHONE.
On the PHONE, you want to push the "OK" button to get to your main tools area:
Choose Settings, then choose Connection:
Now you'll be able to pick which type of connection you want:
You want bluetooth, of course, so pick that:
Now you can specify that you want to add a new Handsfree device (even though, logically, you should go to Setup in my eyes):
Select Look For Devices, at which point the PHONE will scan for available units in the bluetooth frequency spectrum and hopefully find your H700 bluetooth headset. Assuming it does, it'll cheerily report the news:
If your PHONE doesn't find the headset, I suggest that you run the scan another time or two. Also make sure that the H700 is still showing purple, not blue or flashing blue. That should be all you need to do!
Once the PHONE has found the H700 unit, you need to actually pair them, so don't stop here. Select the H700 and you'll be asked if you want to bond the two units:
You want to say "YES", of course, at which point the PHONE will ask you for the bluetooth passkey of the H700, which, like all Motorola bluetooth headsets, is 0000. Enter it:
Choose "OK" to proceed to:
The phone has saved the pairing passkey, now it'll disconnect and search for it again in regular connection mode:
Hopefully it'll still find it, and verify the PIN:
Now, look at the H700. Notice it's no longer in the purple "pairing" mode but has switched to the regular slowly flashing blue mode. You're up, running. I hope this helps and Good luck!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Please remember to vote 459e9de.jpg and leave a testimonial. Thanks.
Nov 02, 2009 | Motorola Mobility H700 Wireless Headset
Motorola h700 pass key
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 22, 2009 | Motorola Mobility H700 Wireless Headset
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
Can't get my phone to pair with my blue tooths. I have two.
i have a sidekick lx and cant connect my bluetooth h700 can you help me.
May 26, 2008 | Motorola Mobility H700 Wireless Headset
Dont know how to work my blue tooth to my phone
You have to get the phone to recognise the bluetooth headset first. The manual should tell you how to do this. Normally you have to go into the bluetooth menu on the phone and get the phone to detect the headset, and then type in the pin code, normally 0000.
Jan 11, 2008 | Motorola Mobility H700 Wireless Headset
Help with pairing
narrow down possibilities
with h700 in off position you held down the center button till it turned pink then opened the mic so that it stayed pink?
told the phone to add new device?
made sure that bluetooth is turned on under settings?
i just got a h700 myself and it was very easy to sync.
Dec 23, 2007 | Motorola Mobility H700 Wireless Headset
Motorola h700
5 Steps
First, CLOSE your boom
Second, Hold the talk button( about 5 secs it should turn to purple color)
Third, DO NOT release the button while opening your boom
Fourth, your BT should be in discover mode( show the steady light not flashing )
Fifth, open your phone bluetooth and search for device. Choose your bluetooth that appeared on the list ( pair code normally "0000" ).
Dec 13, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
617 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
