I have tried over and over to make a espresso or latte, but, my coffee comes out luke warm even though I let it heat up 3 minutes. I have read instructions over and over and just am frustrated. I know I am missing a step or part. Please help me I am dying for a latte.
can ask the service center: Electra-Craft 41 Woodbine St Bergenfield NJ 07621 phone 201-439-1700--Steve Karow fax 201-439-1701 info@electra-craft.com www.electra-craft.com
Was this helpful?
Yes
No
Popular Solutions for Dualit 84024 Espresso Machine
When the coffee maker reaches temperature and the ''Coffee Ready'' light comes on, steam is...
(More)
When the coffee maker reaches temperature and the ''Coffee Ready'' light comes on, steam is discharged into the drip tray via the pressure relief valve and tube assembly. When coffee is made, the water quickly loses temperature and the ''Coffee Ready'' light goes out. I have recently descaled using an appropriate coffee machine descaler and the problem started thereafter. I suspect that a seal in the T-valve has failed, but I don't know why. I have dismantled the machine and inspected the boiler - the element is ok. What appears to be happening is that, as the water reaches temperature, the steam generated is forcing its way back along the pumped cold water supply line, across the T-valve and down the pressure relief tube. I guess the solution is to replace the T-valve, but why should the seals be damaged by the descaler? Is this likely to happen the next time I try to descale?
Hi, I have a Magimix expresso / filtre coffee machine, 15 bar, 2kw, about 3 years old. First the...
(More)
Hi, I have a Magimix expresso / filtre coffee machine, 15 bar, 2kw, about 3 years old. First the expresso coffee came out luke warm, now when I plug it in it trips the fusebox, any advice very much appreciated, many thanks, Jane
It takes forever to fill up the expresso cups the pump is running but it should squirt out and it...
(More)
It takes forever to fill up the expresso cups the pump is running but it should squirt out and it did in the past i havent had it very long
Made a cup of expresso and steamed the milk. Did not remember to turn know clockwise and shut off...
(More)
Made a cup of expresso and steamed the milk. Did not remember to turn know clockwise and shut off steam. It just fizzled out. Went to make cup the following morning and could not turn knob to closed position (arrow should be at top when steam valve is closed, but in my case the arrow remains on the right side - open position and will not move).
