Question about ASUS K8N Motherboard
No signal msg on the monitor - ASUS K8N Motherboard
  • 191 Answers
You have to check:
1) the monitor work ok itself with other PC. (or change a monitor test better
2) open your PC cover look power on work status, power supply work and all fans sunning, then go next
3) change the RAM first slot memory still no msg go next
4) find out any vedio card used (AGP) , and looking for any vedio build-in the motherboard, you may change the monitor sigbal vable
one to another VGA interface,
Posted on Dec 26, 2008
How to fix no signal cable on laptop
Select Fn+ F4 (check 2 monitors) for check the change monitor . if not fix press with out FN.
if not fix go to display resolution and select dual display and duplicate .also select video dislpy LCD or VGA out to Both.
use user manual to more info
Oct 07, 2015 | Samsung Computers & Internet
RWM112310969
Check your computer to make sure it is actually sending out a signal. You can do this by hooking up another working monitor. If the other monitor works, there maybe a problem with the original monitor and it may need to be sent for service repair.
May 12, 2014 | ViewSonic Computers & Internet
Monitor flashes blue light and takes a long time to come on
Disconnect monitor cable from back of the computer and see if u have a error msg on the screen > if u find a error msg like " NO VIDEO SIGNAL"> then ur monitor is fine or else ur monitor is BAD
Oct 20, 2009 | HP Vs17 17" LCD Flat Panel Monitor
No signal msg
first check out the monitor & other cable connection because current leakage is one of the reason.
if all connections are proper then there may b fault in ur monitor or in ur system of the cpu.
in that case i suggest u to show ur pc in repair center.
Aug 14, 2009 | Computers & Internet
"No signal" msg on new Acer X193W LCD Monitor with Vista 64-bit
this should be easy...go to your desktop...right click on it and choose "personalize" it will open up a window. on the bottom it will say display settings...click on it...at the top right it should say "identify monitors" click on that...if that dosent work.click on the monitor that has a 2 on it and it will ask you if you want to add a monitor...it should work
if not, post a comment and i will check back with you
Jun 21, 2009 | Acer X193W LCD Monitor
Monitor going to sleep
turn off the hibernation mode if it is turned on.
Jun 15, 2009 | Dell Dimension 3000 PC Desktop
I have a pavillon a6421 uk hp computer when i turn it on the monitor comes up with no vga signal (i have changed the graphics card and it is still the same) have done all the trouble shooting options...
Hi
First Check the power cable of ur monitor whether power is coming or not..
Then remove signal cable (which is connect the cpu) and then switch one the power, check whether any msg is coming in screen.(like no signal or no connection) if it comes means u want to check the cpu or else their is problem in ur monitor..
Connect the another monitor with ur cpu.Whether ur cpu is working properly..
Sep 19, 2008 | Computers & Internet
My monitor does not light up but just clicks
if ur monitor is not coming up... check uplugging the monitor cable from the tower.... if u receive a msg on screen "No input signal" or "No VGA Signal" then Monitor is working fine... if not received monitor is not working properly.
if Monitor working... open the tower and remove memory (RAM) and switch on the pc... u should get beep codes.. if u dint get it.... Motherboard gone bad....else... try inserting RAM in other slot... even then its not lighting up...RAM problem or RAM solt problem..
Aug 20, 2008 | Computers & Internet
ASUS K8N Motherboard Logo
103 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
