1990 Honda Accord Logo
Posted on Dec 26, 2008
Installing new radio
Which wires are the power wires in the harness that attached to the factory original radio, so I can use them to install the new radio?
  • firekist1218 Jan 07, 2009
    I have sucessfully installed the radio, thank you.
  • Marvin
    Marvin May 11, 2010
    do u still need help?
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Mar 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
10523
Points
26
Factory in-dash wire harness that
snaps into the factory radio.
AS VIEWED FROM MATING END OF CONNECTOR
E F G H I N O P
A B C D J K L M
Note:
using an optional snap on wire harness adapter will simplify the wiring. Most snap on
wire harness adapters have already converted and color coded the wires from the auto
makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years
but may not be the exact colors for this vehicle. This is another reason to use a snap on
wire harness adapter. **
Typical Honda/Acura "Typical" New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H Do Not Use
I Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
2answers
98 Acura cl 3.0 original stereo OEM wires were cut installing aftermarket stereo what are the color codes on the original stock harness so I can route it to the new wiring harness kit
read (you meant main harness to radio sub harness.)
and car may have 5 or more harness for 5 or more very complex radio head end options new,so only the real service manual covers all that for sure,or if lucky 2nd fiddle here.
https://eautorepair.net/Marketing/Default.asp
How to install Pyle radio PLR31MP
remove factory radio ,if you dont have the special tool to do this you can use coat hangers but I perfer using the factory tool sold at wallmart (the cheepest) or autozone push tools into holes on both ends of radio pull radio out. disconect wireing harnes and antenna wire.To install new radio you will need a wireing adaptor and a install kit. These must be spasific to your vehicle. you can buy these online Ebay , or Amazon or off line wallmart or orillys auto parts you will have to connect your new radio wiring harness to wiring adaptor.put install kit on new radio attach antenna wire connect wireing adaptor to original radio wiring push radio gently back into dash with install kit attached. enjoy your new radio. if this was helpful please leave good feed back.
I was installing a new radio in my 98 Mercury villager. Everything hooked up properly to the new wire harness but no sound came out of the speakers. The new radio lit up but no sound. What is the problem?...
you have to connect speaker wire directly to the radio. Don't have amplifier inbetween the speaker and radio because it is not neccessary. If you want amplifier inbetween the radio speaker wire and the speaker then you most likely the amplifier has another power supply wire and hope that the amplifier does not have any additional control wire thats controled by your original radio.
1helpful
After Market Radio Installation
Hey man, you have an amplified system. use a 70-1858 wiring harness and jump the blue/white wire from the aftermarket radio to the pink wire on the second plug. this will power on the factory amp with the aftermarket radio.
Chris-
Im putting in a radio into my 1990 fifth avenue and i cant find a wiring diagram that is correct. i also was wondering if the stock speakers have a amp or something attached?
you can find an adapter that installs between the factory harness on the car and the type of radio you are installing,so you don`t have to cut and splice,you just have to unhook the original radio and install the harness to the original harness and connect the other end to the radio your installing and your done.you can find these at most radio and accessory stores.
1helpful
Putting a new radio in my car, need to know what color wire what.
Here is a website you can go to find which wires are which. http://www.modifiedlife.com I would also suggest going to places like Car Toys and get a wiring harness to make your installation pain free. If you have the original factory harness for the old stereo still on, all that you would have to do is connect the harness to your new radio and plug it in to the factory harness. No cutting wires necessary.
Reconect original radio on volvo s40 2000
easy... assuming you have the original wiring harness
too often the kids that install aftermarket radios avoid buying the factory harness connector and just cut the old wires
8helpful
3answers
Changed Radio - now speakers don't work. I took out the Chrysler radio that had a CD and cassette in it and replaced it with an aftermarket radio. Now the speakers don't work. I got the adapter from a...
Sounds like your Gr Caravan has the premium sound package. You likely haven't hurt anything - but you may need to modify the wiring a bit. The speakers have a tweeter speaker in the center of the main speaker and the wiring goes through that. However, it only worked with the premium package. Go in to the speakers and move the wiring connections from the tweeter to the main speaker. Your other option is to replace the speakers.
2helpful
2answers
Installing an aftermarket stereo, spliced the wires and have everything connected including the remote wire to the factory amp wire but still no sound.
There is no remote wire on these newer trucks....03 and up....u have to buy the harness....although i didnt....i have an 03 gmc sierra and just pulled the schematic and matched the wires. And there is no programming to do on an aftermarket stereo.....I work for GMC and we cant program aftermarket stereos......if u buy the right harness ...and its over $100 then everything should work just fine.....and this does not disarm ur alarm system either....mine still works fine....hope this helps
3answers
Original radio wiring harness
Google Volvo wiring diagram. They are available free. The diagram shows the wire location and colors. Otherwise, run a continuity test with a simple meter to discover a connection with some resistance between a pair of wires. If you here a click or two, from the speakers, you have found the right pair. Continue and label the pairs left, right, front,rear, until all are identified. Then reconnect. A pain but not rocket science.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
