Question about Sony RDR-VX500 DVD Recorder/VCR
How to reset recorder
I mistakenly put the progressive scan on when I was setting up the recorder...Now I cannot go any further in setting up as the tv screen is just black. Is there any way to start over? I have tried unplugging and replugging & also holding in the "on"button trying to reset but the progressive light just keeps coming back on and the tv goes black. Thanks for any suggestions
  • Anonymous Oct 02, 2008
    the progressive light remained on
  • Anonymous Mar 13, 2009
    me also faceing a same problem.plz any body heplp me..
    with best regard's
    Khurram shujaat
    Problem Solver:
  • 3 Answers
The solution to hold the pause button for 5 seconds is a winner. Just make sure you press the DVD button first. This doesn't work in VCR mode. This button is on the actual unit, NOT the remote. Thanks for this help.
Posted on Oct 02, 2008
I tried using the first solution and it didn't work for me using the remote control... so I called sony 1-800-488-7669 and was told to press and hold the "Pause" key for 5-10 sec. on the DVD player itself, NOT on the Remote control. It should turn off the progressive scan... It worked for me... hopefully it will work for you too... if not... just call them!
Posted on Oct 05, 2007
Thanks awesome for the number! i called and customer support said to do the following - " make sure no movies are in it, have it on dvd mode, and then press and hold the pause button for 5 seconds." i thought i did that, so just in case i got directions on what buttons to press as if you could see the screen. - " press setup, press down four times then enter, press down twice then enter, press down three times then enter, press down once then enter." that should navigate to the progressive scan option and turn it off.
Posted on Oct 03, 2007
    Problem Solver:
  • 8 Answers
Call 8002227669 or 8884766972 to have Sony tell you how to correct the problem.
Posted on Apr 18, 2007
While going thru the settings on the dvd part of my sanyo dvd/vcr reciever it went to progressive scan mode and now i can't get back to the setup part to turn it off, can you help me?
If your TV has component video inputs then it will work (and give you improved video quality) in progressive mode. If not try leaving it unpluged for several hours to see if it resets itself. Otherwise refer to your owners manual to see how to reset the settings.
Aug 17, 2011 | Sanyo Cinematic Progressive Scan DVD...
My zenith xbv343 dvd vcr combo has a problem when i put on a dvd it says progressive scan mode i cant see nothin else
Hello
That means the DVD you put into it to play has recordings with "progressive scan" mode. You have to change the mode of the DVD and TV which you wants to see to Progressive Scan mode to see the disc content. OK.
May 09, 2011 | Audio Players & Recorders
RDR-GX315 was accidentally reverted to "Factory Settings" ... now we can get sound but no picture and progressive is turned on and we need to turn it off.
If your TV has progressive scan capability, you may be able to view the on-screen setup menu via the recorder - select 'SETUP' press 'ENTER' on your DVD recorder's remote to bring up the menu - with the remote arrow buttons, scroll down to select 'VIDEO' then 'PROGRESSIVE' - highlight it then set it to OFF (you cannot do this with a TV that does not support progressive scan from this unit). Once done, exit the setup menu and it should work fine with all the other settings. If your TV doesn't have progressive scan, connect the DVD recorder to one which does and turn its progressive output off there. I assume you still have the user manual for your recorder (if not, you can download it online for free as an Adobe document - .pdf. Page 73 details the setup steps for this model). I hope this tip helps somewhat.
Feb 11, 2011 | Sony RDR-GX315 DVD Recorder
How do i reset a vistron dhr 5006 dvd hdd recorder
Press and hold STOP button on unit for 6 seconds to cancel progressive scan mode.
Still no joy? put yellow video cable in GREEN pin ( component out) and you will get b/w image in TV to get access Menu to cancel progressive scan there.
Thanks.
Jun 10, 2009 | Televison & Video
I put my dvdr phillips recorder on progresive scan no picture
You will have to reset the DVD player in order to undo the progressive scan option. Since you cannot see a menu to do so...
1. Unplug the dvd player from the outlet
2. Press and hold down the STANDBY-ON m button on the front of the Recorder while reconnecting to the power outlet.
3.Release STANDBY-ON m when '  ' appears in the display. All the information stored in the memory (programs, time, TIMER) will be reset (cleared).
Hope this helps with your problem, thank you for stopping by Fixya! Please leave a positive rating if this solution works for you.
Mar 15, 2009 | Philips DVDR615 DVD Player
Magnavox mrv640-accidentally turned on progressive scan
Had exactly the same problem. You need to reset the DVD recorder to it's default setting. The default is "interlaced".
From the users manual.........
Switching the DVD Recorder
Disconnect the recorder's power cord.
2 Hold down the FF button (arrow pointing left) the front of the DVD Recorder while
reconnecting the power cord. 'PRO' (progressive scan) will appear
on the display.
3 If you want to switch back, repeat steps 1 and 2 . 'PRO'
(progressive scan) will disappear from the display. The DVD
Recorder is switched to 'Interlaced.'
The manual is at:
http://www.m4c.magnavox.com/files/m/mrv640_17/mrv640_17_dfu_aen.pdf
See page 12
It worked for me.
Mike
Jan 31, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Progressive scan
I too have tried scanning two different Philips 3390 DVD records with the same results. So far Philips have not come up with a solution. I would appreciate it if anyone out there could shed some light on this problem? It does not appear to be a one off situation.
Thanks in advance.
Feb 23, 2008 | Philips DVDR3390/37 DVD Recorder
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
How do I reset this ilo dvdr05
To reset to user defaults for mu1 with no video: 1. turn on dvd with no disc 2. press "setup" 3. press "down arrow" 3 times 4. press "enter" 5. press "down arrow" 9 times 6. press "enter" More than likely you changed from interlaced scan to progressive scan. If your tv does not sopport progressive scan there will be no video. The default setting is interlaced scan.
Dec 07, 2006 | iLO DVDR05 DVD Recorder
Sony RDR-VX500 DVD Recorder/VCR Logo
1,387 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
