Question about ViewSonic VA902B 19" LCD Monitor
Monitor Flickering and Sharpness control is disabled
My viewsonic is flickering since I installed Windows XP. I got and installed the latest drivers but it still flickers and my sharpness control is disabled.
    President:
  • 2,961 Answers
It will probably be the graphics driver you need to update as XP probably loaded generic a graphic driver. The monitor should be ok with a standard driver.
Posted on Apr 18, 2007
Veiwsonic VP2365wb backlight flickering
If it's not under warranty, buy a new one from newegg dot com.
Mar 27, 2013 | ViewSonic VP2365WB 23 inch LCD Monitor
MY MONITOR MODEL IS LG FLATRON T705SH I CANNOT ADJUST MY SCREEN RESOLUTION I WANT TO KNOW THE VALUES SUCH AS POSITION: SIZE: SHAPE: PLEASE HELP ME OUT SIR AS SOON AS POSSIBLE
Your monitor supports a maximum resolution of 1280 x 1024. If windows fails to give you the option of changing to this resolution and those below it then please follow these suggestions:
Update your video card drivers, if you don't know the manufacturer of your video card try windows update.
Install the latest drivers for your monitor as well.
Your monitors driver click HERE
May 04, 2011 | LG Flatron F700B 17" CRT Monitor
I have installed viewsonic va1716w monitor using windows xp. I am unable to set its resolution to 1440X900. from display properties it going from 1024X768 to 1280X1024
It is possible that the video driver cannot support 1440X900 resolution.
Try installing the latest video driver and then try the higher screen resolution.
Mar 19, 2011 | ViewSonic VA1716w Monitor
Horizontal lines flickering
  1. Mybe VGA driver instalation not compatible with your monitor screen, you must check there are OR if you are use External VGA mybe theyare not compatible with your motherboard system
  2. if not work you must bring your monitor go to service hard,because your computer,because most likely your monitor easy damaged. good luck
Apr 25, 2010 | Microsoft Windows XP Home Edition
Trying to get rid of flickering on screen. now an
Flickering is caused by the incorrect refresh rate being used by your graphics card, go into the graphics settings by right clicking your desktop and choose the correct resolution and refresh rate dependant on the screen size and options. TRYING ALL THE OPTIONS DOES NOT CAUSE ANY DAMAGE TO YOUR PC OR MONITOR. Just pick the setup that suits you.
Oct 22, 2009 | ViewSonic VX2035WM LCD Monitor
I have pentium computer - D815EEA2 Motherboard P-III, 733 Mhz. CPU Now i purchase viewsonic VA1918WM Monitor and picture is flicking, and only one setting of resolution in 1024 by 768 pixels High (24 Bits)...
The reason you are getting the flickering is because the refresh rate is not set correctly. Click on Start>Control Panel>Display>Settings>Advanced>Monitor. In the middle of the window you will see the refresh rate. It should be set between 60-75. Try setting it between that range and try it a few times until the screen stops flickering.
Thanks for using FixYa. Don't forget to vote on this solution before you log out.
Jan 20, 2009 | Computers & Internet
HELP ME FIX MY MONITOR PLEASE
same thing is happening to me except when i turn on my computer, you can see the screen and its flickering then a few seconds later it turns all black.. :( !!
Dec 04, 2008 | Computers & Internet
Monitor flickering
Do a debug and re-install the video driver.
If doesn't work , let me know.
~Nitin
Feb 28, 2008 | ViewSonic VX2245WM LCD Monitor
Monitor flickring
  1. Flickering screen display
    Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
    • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
      • a TV set
      • a laser printer
      • another monitor
      • fluorescent lights
      • hidden power lines
    • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
    • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
    • The number of devices using power from the same electrical line. Are you overloading the plug?
    • Monitor placed on an unstable surface.
    • Improper video drivers, this is a software problem, see section B
    • An improperly configured or a defective video card.
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
ViewSonic VA902B 19" LCD Monitor Logo
452 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
