Question about ASUS Celeron A
Repair motherboard always my computer restart, when i am shutting down the computer. now no display the monitor. I am giving the motherboard in servicing centre, but he do not repair the motherboard. so please help me.
  • ajay301287 Feb 13, 2009
    mather board very hiting
  • Chris Fell
    Chris Fell May 11, 2010
    A number of questions for easy answers:
    is the power supply good?
    is the hdd,cd/dvd,cpu cooling fan all working when the pc is switched on, no display on screen, screen remains at yellow standby light ?
    Make and model of board please
    compdoctor2005@btinternet.com
I wont this matharboard driver
Posted on Feb 13, 2009
    Sergeant:
  • 270 Answers
Try to service in manufacture autherised service center.
Posted on Jan 15, 2009
The computer start after 3 or 4 attempt when I press the power button. When the computer is on & I restart my computer from Start - Turn off computer - Restart. - my computer shut down instead of...
If the computer is not truing in first attempt then check for the earthing is OK or not. Then check the power is correctly supplying or not. There may be a chance in loose connection of the switch of your cabinet. If the system is shutting down when you give restart, then it may be problem of power. If the power part is is OK then the operating systems is to re-installed or repaired.
Jan 13, 2011 | ASUS M2NPV-VM Motherboard
My graphics card has lost the colour red
Are the cables tight - I had to ask, always try the simple things first.
You could try to:
Shut down the computer
Open the case - while you are there, blow out any dust which may have accumulated
Remove the video card (unless it is built into the motherboard) and replace it again
Close the case and restart.
No good? Go to Start/control panel/device manager and click on the video card.
Right click and remove device
Shut down and restart the computer
Still no good? Then the problem could be (and I think it may be) a bad monitor. Can you borrow another for a check?
Dec 24, 2010 | ASUS Computers & Internet
The computer was in use when the display cut out. The monitor is fine and the computer turns on but has no display on the monitor
I presume that you tried the monitor on another system to verify function. Try restart after 2 min power down and disconnect and try again, then take another "known good" monitor and try that. If both monitors give no image, video output is suspect. Many motherboards have the video output as part of the board itself, cost prohibitive to replace motherboard.
Sometimes you can plug in a PCI video card and bypass system video.
Oct 01, 2010 | Gateway GT5622 PC Desktop
It's lg lcd w1943T that always shut down after 30 minutes and states power saving mode analog
check your video card and update the driver or pe install your video card. add cooling system. another is the motherboard capacitors
May 11, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Software shuts down. says not responding. has
hi,, it can be an problem with your RAM,,mostly,, or else can be your motherboard / processor, but first you have to try replacing your RAM..with other ones
Sep 27, 2009 | Sony Vegas Movie Studio for PC
I have a Gateway FPD1975W TFT LCD Monitor which often works when plugged in to a computer but when plugging it in to my laptop it keeps displaying a green box that says "Frequency out of range" instead of...
the laptop needs to have the display settings and the adapter or monitor setting changed to a lower freq, like 60 hz
display settings/ advanced/ monitor/ change setting to 60 hz, that should fix ya let me know if it works.
don't forget to rate when its fixed.
Jan 14, 2009 | Gateway FPD2275W LCD Monitor
I see two screens on my desktop.
You are using a screen resolution that is not supported by your monitor. Start the computer in safe mode and open display properties. What ever resolution and color depth is (usually 640x480 and 16 colors), click OK button. Restart the computer. Go to display properties and increase the color depth to the maximum value. Set the resolution to 800x600. Restart the machine. Do you see double screens? No? Great! Now try increasing the resolution to the next level. (1024x768). When you click 'apply' you will be give 15 seconds to say it is OK. So if you see double screens, do not click anything. Display will revert to 800x600 resolution (and you will see only a single screen!)
Sep 21, 2008 | ASTVision 5B 15 in.CRT Conventional...
Computer not started properly
the window is corrupt try to repair the window with window xp
May 30, 2008 | Intel D845GVSR Motherboard
Alarms
Hello, find the BIOS Beep Codes at http://www.amptron.com/html/bios.beepcodes.html and try to find your problem. It is not a software or Monitor problem. It could be RAM or Video Card failure
Aug 04, 2007 | Biostar M7VIZ Motherboard
ASUS Celeron A Logo
315 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
