Question about Frigidaire GLWS1349A Top Load Washer
Washer leaking We just recently bought a washer from someone, and moved it to our house. It worked before we moved it, but now it will not. The wash cycle works untill it comes to the spin cylce. Then the water does not drain thought the pump like it should. It goes through the holes into the outter part of the drum like it should but then comes out though the vent holes on the top of the drum causing the water to go all over the floor instead of into the drain. We were wondering if this is a problem with the pump, or if it could be something else. Thank you
    President:
  • 1,462 Answers
Hi tyree. you were on line to me but disappeared. did you get what i sent on what prob may be?
Posted on Apr 18, 2007
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
Sep 12, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I Have a combo kenmore washer/dryer model # 417.94712400 and I need to open the washer to inspect a water leak. how do I open this washing mashine.
Remove the 2 screws at the base first
If ya run a load with the front off to look for leaks remember there are moving parts
I recently worked on a dryer portion and took these photos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 25, 2011 | Washing Machines
We had this unit for about 4 years. We've just recently moved and brought our washer with us and now we have a leak that is showing up on the floor. The unit is working fine except for this leak. What do...
sounds like someone may have disturbed the drain hose or pump, tilt the washing machine forward and look for wet spots underneath when it is empty of course.
Feb 09, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Moved into rent house and washer drain backs up and overflows
If the washer isn't yours (ie., it was included with the house and not one you bought), don't bother doing anything yourself - tell your landlord to come fix his/her washer!
Oct 26, 2009 | Maytag Washing Machines
Dishwasher is leaking water. Water is puddling
There is a tube on the side of your dishwasher for over flow. It sounds to me like your washer was moved and it banged against that line. You can put some caulking around where it enters the washer and that should be fine. The bottom can be several things. If your washer was removed and reinstalled like say maybe floor installation the supply line, or waste line may not be tight. If your unit has not been moved recently it is most likely the motor housing. Take off the one or two covers on the front bottom of the washer. Place the washer through the cycles and with a flashlight see at what cycle and where the water is coming from. It it appears to be coming from the white housing it's the motor. It's cheaper to just replace the unit as these motor housings are around $150.00. Check out craigslist. Hope this helps.
JimmyC
Sep 25, 2009 | GE Dishwashers
Samsung washer
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 28, 2009 | Samsung WF337AA Front Load Washer
Wd63 does it have a filter to empty for the dryer!?!
Hi there sarah
The hotpoint washer dyrer does not have a filter for fluff
100%
Need any other help dont hesitate to ask
Jan 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Kenmore 43142 Front Load Washer
Have you switched the power on? you could try a radio or something in the socket. Have you turned on the water valves? Tom.
Feb 28, 2007 | Kenmore 43142 Front Load Washer
Frigidaire GLWS1349A Top Load Washer Logo
71 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
