Question about Frigidaire Affinity 5.8 Cu. Ft. Super Capacity Electric Dryer
Dryer not coming on (code "dr")
My dryer suddenly stopped working. Once I close the door, I am able to choose the setting. When I then go to pust the start button, I get a double beep and "dr" shows up on the display. I must say that the door was loose for a long time, and we were slamming it to get it to shut tightly. The last time it worked and I opened it, there was a spark that came from the door. Lastly, we already reversed the door. Please let me know you thoughts and if it may be a problem I can fix. If I can't fix it, what is the best way to present it to the repair man so he doesn't try to rip me off.
  • Anonymous Jan 20, 2009
    I also get dr in every setting except for touch up. It will only dry on touch up for 15 minutes at a time.
    New Friend:
    Problem Solver:
  • 18 Answers
Many of the washers and dryers that use digital control have door switches. A non-working (damaged) door switch will prevent the appliance from working. Look up online for a manual for your appliance and see what they show for your unit. If you get the diagram on how to dismantle it to replace the switch you can see if you think you can handle that task.
Then look online for the parts, and compare the cost with your local suppliers.
I just replaced such a switch for a friend. The switch cost locally was $109, but I found a new one online for $45. It took about an hour to change out the old for the new.
Posted on Apr 20, 2017
SOURCE: Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Posted on Feb 10, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Fridgidaire Dryer runs constantly when plugged in
You have a couple different options. One is to check the timer and make sure that it is working correctly. Second thing is to check the computer and the fusees to make sure all is well.
Posted on Feb 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire Dryer only runs on "low Heat" setting
Mexitronics
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 20, 2009
dniro592006
  • 121 Answers
SOURCE: Door does not stay closed
your door clip needs to be replaced or realign
your door
Posted on Jun 12, 2009
SOURCE: Frigidaire Electric Dryer error code "dr"
I just ran the Function test sequence which is in the Dryer Tech Data Sheet (this sheet is inside the dryer at the lower right side) and after that the machine is working. I hope this can solve your problems too.
Posted on Jan 10, 2010
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
Roper dryer repair manual
90% it's the timer
Jan 30, 2014 | Dryers
Wont turn
The model number listed above is for a refrigerator. It sounds like your belt broke or the Idler assembly failed. Not very much in parts cost. You will have to take the dryer apart to fix the problem. It is a minor problem and usually worth repair.
Feb 20, 2018 | Whirlpool ET8CHEXSQ Dryer
Frigidaire error code dr
Dr is just a door error code. Make sure it is closed all the way and reaches the door strike correctly.
Aug 04, 2012 | Frigidaire Electric Dryer
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Was using the dryer and it was operating fine. Opened door to take clothes out. When closed door and pushed button, dryer did not start. Light is on and safety switch appears to be functioning because...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 24, 2011 | Kenmore 63942 Dryer
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Maytag Dryer - Model # MDE3000AYW - Serial #13248282UU The dryer was working fine then the next time I hit the start button nothing happened.
Hi and wlecome to FixYa, I am Kelly
There are several things that can cause this.
1. The door switch Item 6 of link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45255&diagram_id=28471637#d28471637
Listen for an audible click as the door is just opened or closed. No click = failed switch. Alternate means of tesing is with a meter. Switch plunger depressed = continuity
2. The thermal fuse Item 10 of link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45255&diagram_id=28471639#d28471639
This is a non resetable fuse it either reads continuity or open. Open = failed
3. The pust to start switch has failed. Item 12 of link
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45255&diagram_id=28471636#d28471636
4. Failed timer Item 7 of link:
Items 1, 2 and 3 above are the most common failures in the order listed.
Wiring data can be found here:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28471641&pkw_=basket&model_id=45255&NewWindow=1
If you need more help or assistance just respond here and I will gladly help you.
Thanks for choosing FixYa,
Kelly
Jan 22, 2011 | Maytag Dryers
My dryer shown dr on the display. why is this
Hello. This is an open door circuit code.Either the door isn't closed completely or there is a problem with the latch switch,could also be a main board problem.Try to start it on an air fluff setting (no heat), if it runs on this setting the door switch is ok but something else is wrong.
builderdale
Jan 18, 2010 | Frigidaire FEQ1442ES Electric Dryer
Code dr on display, won't run on any cycle except for 20 mins low
user interface is not detecting that the door is
closed. either door switch is bad or need to replace interface
Jun 08, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Affinity 5.8 Cu. Ft. Super Capacity Electric Dryer Logo
77 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
