Question about Microsoft Xbox 360 Console
Xbox wont turn on
The xbox has blown the fuses in the house and the xbox will not turn on now
    Problem Solver:
  • 10 Answers
You should buy a new fuse for it on the internet
ben and peter jeffrey
Posted on Dec 26, 2008
My dryer wont turn on at my house but will at the neighbors
Dryers are 220 volts. Have you checked the circuit breakers? If you have an old house, you may have blown one of the two fuses in your electrical panel.
Use a voltage meter to check the voltage of the outlet.
Jan 19, 2014 | GE DWXR483EBCC Electric Dryer
My xbox got milk spilled on the top and now wont turn on
it has blown the micro fuse's you will need to have them replaced.
Oct 25, 2013 | Microsoft Xbox 360 Console
Wont heat up
Good Morning Johnnie, thank you for your post!
Often when a dryer no longer heats, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and one also may have tripped. Typically, the heater of a dryer requires 220 to 240 volts to operate. If none of the tips above solve the issue, then it could potentially mean a number of other things: defective cord, a wiring failure, faulty heating element, or control board. Which in the case, I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Sep 10, 2013 | Frigidaire Dryers
My 42lh30 lg tv was on the kids where watching movie on xbox then the tv and xbox just turned off. and will not come back on. the xbox is working. but there is no red light saying the tv is getting power....
Possibly you've had a power cut & a fuse associated with the TV has blown. Have you checked the fuse in the TV plug? If that's ok then probably a fuse internally in the TV has blown or something more serious has blown in the power supply
Aug 25, 2013 | LG M4201C-BA 42 in. HD-Ready LCD
T.v. wont turn on.
you might find that the power cut has blown the tv does happen - check the fuse first in the plug
Jan 24, 2012 | iLO Televison & Video
The dishwasher wont turn on. I'm not sure if is fused or not. How can I fix it?
Many dishwashers, due to their power consumption, are on their own house circuit. It may have blown the house fuse or circuit breaker. Ours does it about once every 6 months or so. I just reset the circuit breaker. I'm sure an electrician would tell me to replace the dishwasher or have it serviced to determine why it periodically blows the circuit, so if it has blown the circuit breaker, you should determine why before running it again (unlike me!).
Nov 07, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Xbox 360 wont turn on
this is usually due to a faulty power and/or a blown fuse
Jan 31, 2010 | Microsoft Xbox 360 Console
Lightning strike
Yes there is a fuse, but it is integrated, i.e. a soldered component in the main board. A manufacturers warranty fix would be your best bet or failing that a manufacturers recommended engineer. Please don't use an unqualified person as the main board can be blown if too much heat is applied when changing out the component part.
Oct 12, 2017 | Vizio L32 32 in. LCD HDTV
My dryer ran all day long. The timer was still in the same position as when I left the house. The 'regular' heat is now not working either, air fluff only.
one of the fuses in your house's fuse box is blown check both fuses for continuity and replace the blown fuse you only have 115 v coming to the dryer which will run the motor but wont run the heat or the timer let me know how you make out and dont forget to rate this suggestion thanks
Aug 05, 2008 | Maytag Dryers
Microsoft Xbox 360 Console Logo
285 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
