Question about Bowflex Treadmill Series 7
Mind of its own
I have a freesprit treadmill that is about 8 years old. It has has started to speed up ans slow down and even stop. There is no pattern. The console stays alive but resets itself. After it has stopped I can restart it again.
Any suggestions?
  • 827 Answers
Hey there Ian,
If your treadmill has an optical speed sensor and hasn't been cleaned for a while, dust, dirt or lint may be obstructing the infared eye of the speed sensor. Try cleaning the treadmill.
Or maybe you need to replace the upper display, although, you may have a loose wiring harness that would cause the same problems. Open the motor case and verify the wiring harness is plugged into the lower board snugly. Also, remove the upper console and verify the harness is plugged into the back of the console snugly as well.
The only other thing I can think of is that maybe the Invisible Man has been squatting in your house and is training for the Marathon :)
Definitely, inspect the components and try and isolate the source of the problem yourself first, before contacting a dealer for parts, as they can cost a fortune..
Good Luck!
Chris (ziraffa)
Posted on Dec 26, 2008
My treadmill slows down lately on its own. What could it be?
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 09, 2017 | Weslo Exercise & Fitness
Precor 9.27 treadmill won't slow down
Hi, It's probably the speed censor. Clean it up and should be good to go. When you disasemble it clean all other parts and put back togeather. Good luck
Jan 23, 2014 | Precor 9.27 Treadmill with Ground Effects...
Life fitness 95t speeds up after confirming slower speed in cool down mode, and also pauses after touching increase button on screen. both issues are dangerous
book an engineer, sound like motor controller, loose belt could also be a issue, needs a safety check where are you based ?
Jan 27, 2013 | Life Fitness Exercise & Fitness
My tread mill will sometimes slow down and then all of a sudden will speed up. It is around 8 years old and no maintenance has been done. What can be done to solve this issue?
CompartirFacebookTwitterGoogle+DeliciousDiggGoogle BookmarksMySpaceStumbleUponRedditMessengerVodpodYahoo BookmarksBeboMister-WongWordPressGoogle ReaderOrkutXINGEvernoteNetvibes ShareStrandsPosterousBusiness ExchangeArtoTipdSmakNewsPlurkAIMYahoo MessengerIdenti.caMozillacaBlogger PostTypePad PostBox.netNetlogTechnorati FavoritesCiteULikeJumptagsHemidemiFunPInstapaperPhoneFavsXerpiNetvouzWinkDiigoBibSonomyBlogMarksTailrankStartAidKledyKhabbrMeneameYoolinkBookmarks.frTechnotizieNewsVineMultiplyFriendFeedPlaxo PulsePingSquidooProtopage BookmarksBlinklistFavesYiGGWebnewsSegnaloPushaYouMobSlashdotFarkAllvoicesJamespotImera BrazilTwiddlaLinkaGoGounalogHuggDiglogNowPublicTumblrLiveJournalCurrentHelloTxtSpurlYampleOneviewLinkatopiaSimpyLinkedInBuddyMarksAsk.com MyStuffViadeoMapleWistsConnoteaBackflipMyLinkVaultSiteJotSphinnDZoneCare2 NewsHyvesSphere***** BrowserGabbrSymbaloo FeedsTagzaFolkdNewsTrustAmazon Wish ListPrintFriendlyRead It LaterTuentiEmailRediff MyPageGoogle GmailYahoo MailHotmailAOL MailAny email By Lockerz 1) probably a faulty speed sensoR 2) the speed sensor is not plugged in properly3) adjust the speed sensor 4) Use the calibration software under the hood and follow the step indicated for easy diagnostic and fix it. 5) Its also possibly a faulty main motor See the tip 6) control board or lower board faulty measure the 115Vac for input., and then output for +5Vdc,
12_27_2011_7_27_46_pm.jpghttp://www.fixya.com/support/r10786838-test_procedure_dc_motor
12_27_2011_7_30_32_pm.gifsincerely. Happy New Year. G-d bless you.
ernesto cuadra
managua, nicaragua. c.a.
Dec 27, 2011 | Nordic Track Exercise & Fitness
T3 - It slows down then speeds up, has mind of its own.
It sound like the Motor Control Board is failing call Life Fitness @ 1-800-351-3737 they will give you additional information and locate a servicer in your area
Jun 12, 2010 | Life Fitness T3 Treadmill with Advanced...
SOLE F80 TREADMILL STARTS TO RUN THEN STOPS. "LSI" OR "L51" APPEARS IN THE TIME BOX AND "LOW SPEED" APPEARS IN THE DISPLAY
SimplerFASTERSolution So, I had the same problem. After removing the motor cover I checked everything out per earlier instructions. Everything looked great. Having been a software geek for as long as I've been running (35 years), I as inclined to believe this wasn't a hardware problem at all. It appeared to me that the system just needed to be recalibrated. So...here's what I did. I turned the treadmill on and selected the "Manual" program and hit "Start". The monitor, as usual, counted down 3-2-1. As soon as the rollers started to move I hit the "Slow" button on the right upright several times so I knew that the treadmill was running at it's slowest speed. I then started walking on the belt. I started tapping the "Fast" button and let the belt gradually increase in speed and took it up to 6.0. No problem! But...nobody wants to start each workout that slowly. I had a hunch it was 'fixed'. So, I stopped the treadmill and turned everything off. I started it again, selected "Manual", immediately hit the "2" then he "4" then the "6" on the right hand "Speed" panel, and it ran like new. No service call, no new speed sensor, no fiddling with the little 'diode', etc. Give this a try first...no need to even remove the motor cover. Best of luck!
Apr 26, 2010 | Fitness Giant Sole Fitness F80 Folding...
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Bowflex Treadmill Series 7 Logo
161 people viewed this question
Top Bowflex Exercise & Fitness Experts
Jerry Greenberg
Jerry Greenberg
ptpumpman
Jesse Garza
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
