Question about MSI RG54G2 Router (MS-6848-002)
Wireless Router RG54G2
HI, I'm trying to access the Web Browser control panel for the above router using the default password, but it does not accept the password (any ideas, apart from the obvious as I can't remember having changed the password at any time) ? Many thanks.
    President:
  • 2,961 Answers
Assuming you have tried without typing a password; try admin or password or router admin. You can reset the router by a hole recess normally at the rear of the unit using a pen tip and push it in for 5 seconds or so.
Posted on Apr 18, 2007
How do I reset my password?
Step 1:
Wireless networking is a common feature in homes and offices. Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network. If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu. Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings. Disable the wireless security. Reset to Factory Defaults Locate the reset button on your router. Typically the reset button is a small indented hole on the back of the device. Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings and add security as necessary.
Feb 27, 2013 | Computers & Internet
I need to lock my router from neighbors using it
For that you need to secure it with WEP password you can set it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security then enter new password then save settings and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 27, 2011 | NetGear WNR1000 Router
How to change password
to change the password, assuming you have not changed the default administration passwords point your browser to "192.168.1.1" Once there you should have a login screen. linksys default is "administrator" AND "admin" as the username and password. Here you should have access to the full control panel. You can change the wireless password as well as any other settings.
Mar 07, 2011 | Cisco Linksys WirelessG Broadband Router...
How do I change the ssid and make secure
Securing the router:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696
Changing SSID:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 05, 2011 | Linksys Wireless-G WRT54G Router
Need to change my password how do i do that?
Welcome to Fixya. If you want Password on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure.
Thanks for using Fixya.
Feb 14, 2011 | NetGear WGT624 Wireless Router
Router will now accept my security code to connect my wireless components, using one given to me by tech, how do i find out without paying dlink 40 dollars
  1. Open your D-Link router's control panel by going to the IP address http://192.168.0.1/ in a web browser. You will be prompt for a password. If you did not setup a password on your router, the dlink default password is usually blank. Enter admin for the username and leave the password blank or enter your password.
  2. Click on wireless and under security. There you will see your security key.
  3. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 04, 2011 | D-Link DIR-628 Wireless Router
Need to reset to connect wirelessly to Internet
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access it with above ip then press RESET button for 10 seconds then all settings defaults. Then you can access it with above default ip. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa. .
Oct 07, 2010 | MSI RG54G2 Router (MS-6848-002)
Hey i have a problem i whant to put my wireless router on code/password so can u help me and explane me how to do that?
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jun 29, 2010 | MSI RG54G2 Router (MS-6848-002)
I have a 2wire wireless router but i've had it hooked up to my airport express as the wireless router. How do i get the 2wire to function as the wireless router? only the DSL light lights up, not the...
Since the Wireless light is off, lets assume that the access point is just switched off.
That function is switched on and off from the router's control panel accessible via web browser. And you can follow these steps to get to the Wireless configuration control panel.
Open this URL from your browser
http://gateway.2wire.net.
If you have a system password enabled (and it's asking for it) but you didn't set it, or you forgot what it is you can click the
can’t remember the password
link if the password hint does not help you. In order to reset the password, you'll be asked to enter a 10 digit code which you can find on the bottom of the router itself.
Once you're able to gain access to the control panel, you'll want to
  1. click the 'Home Network' tab
  2. click the 'Wireless Settings' link
From this panel you can make changes to how the wireless access point portion of the router is configured. By default your router's wireless should be on, but since it's not I'm going to assume at one point in time someone turned it off so it wouldn't get confused with your airport express. If you just want your wireless settings back to the default settings
  1. click the 'RESTORE DEFAULTS' button
Then the wifi settings will be set to how they were when the router was purchased. By default the access point is secured by WEP encryption, and the key is located on the bottom of the router by the Serial Number.
Apr 22, 2010 | 2wire (2701HG-B) Wireless Router
Ipod touch - wireless connect to my MSI RG54g2 router
Hi and welcome to FixYa,
Initially, to your queries:
  • instruction book - pls click here;
  • passwords - open a browser, the MSI RG54G2 web interface is 192.168.1.254, password is "admin", less the quotes;
  • iPod touch - will auto detect your MSI
  • setting on my router - if allows your computer(s) to access the Internet, no further settings required;
  • iPod can connect to the internet - if no WEP or WPA is set on the MSI router.
This is of course assuming that the MSI RG54G2 is allowing your computers to access the Internet lready and will be shared to the iPod Touch.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 25, 2008 | MSI RG54G2 Router (MS-6848-002)
MSI RG54G2 Router (MS-6848-002) Logo
589 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
