Question about Brother XL-5340 Mechanical Sewing Machine
Putting my machine back to operating order
The entire needle housing unit fell, including the thread guide. I can't figure out how to put it back together again. HELP
  • Chellirae May 03, 2008
    Does anyone have any idea how to put the needle holder back in. I looked in my manual and I don't see anything. It will not stay in. It seems that the thread holder might help to keep it tight, but it still falls out everytime I sew, very frustrating.
  • 944 Answers
Go to this link; http://www.sew4less.com/manuals.php and select your machine brand and model. Unfortunately they are not free, but you can purchase the instruction manual, the parts manual and the service manual of you wish. Sorry i hunted for free ones with no success. Hope this helps :)
Posted on Apr 18, 2007
SOURCE:
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
How to put a thread cutter in husqvarna viking desinger se sewing machine
I believe the plastic cover (gray?) toward the end of the arm (left of the needle plate) is removable by prying (gently) on the front edge and sliding toward you. Unless the cutter is broken, you should be able to figure out how itall fits back together.
Dec 21, 2012 | Husqvarna Sewing Machines
When I try to sew my bobbin thread is not picked up.
try a new needle failing that you may need to retime the machine
Aug 10, 2011 | Kenmore Sewing Machines
Need to know how to thread the bobbin
there is a guide on the plastic cover which is a good guide as to the direction, but before you put the cover back use the top thread to pull it through by putting the needle up and down and replace cover
Aug 29, 2010 | Janome Memory Craft 9000 Computerized...
How do you thread a pfaff 7570
If only we could put video links in here! But here goes:
Raise the presser foot;
Turn the hand wheel until the take-up lever (the hook bit that goes up and down, above the needle ) has reached its highest position;
Remove the small spool holder from the horizontal thread holder that is under the lid. Put thread reel onto spool, replace spool holder;
Pull thread behind first thread guide - it is the cream flat plastic bit towards the back - about 1" x 3/4" (i.e. the thread takes the first exit at the back);
Bring it down the left-hand long slot on the front of the machine, back up the right-hand slot, over the hook of the take-up lever, back down the right-hand slot and pass it from the side between the thread guide (silver metal bit just above the needle - looks a bit like curled metal). I found this last guide the most difficult to figure out - tried to get the thread into the curled bit - but you don't do that - it just slips in behind;
Thread goes through the eye of the needle. You can use the needle threader or not. Instructions for needle threader:
Lower sewing foot (makes more room and clamps the thread in the upper tension discs so it is less likely to keep spooling off while you are trying to thread);
Turn handwheel until the needle is in highest position;
Pull the needle threader straight down and then twist it to the front so the tiny hook on the threader goes through the eye of the needle;
Take thread under the larger metal hook on the left, put your thumb on it to stop it coming off, thread goes back towards the needle and under the small hook that is poking through the needle from the back;
Twist the needle threader towards the rear, releasing the thread carefully and allow the threader to move upwards. There should be a loop of thread left in the eye of the needle and you can now pull it all through to the back.
That sounds really complicated but I find the Pfaff needle threader works really well, unlike that of some other machines. I also have a Husqvarna Designer 1 whose needle threader works great, but the one on my friend's Designer SE is useless. Go figure!
Feb 02, 2010 | PfaFF Creative 7570
I can seem to get the bottom thread up
Try replacing the needle. sometimes a bent needle causes this.
It sounds like your timing may have been altered when your bobbin housing fell apart. This is difficult to repair without specialized tools and knowledge, so best get it to a repair shop.
If the machine is a common brand like Singer or Kenmore, go online and search for a manual. Many are available for under $10 or are free to download.
Nov 02, 2009 | Sewing Machines
I have a Bernette 50 sewing machine....i was sewing velcro....the screw assembly on the post where the needle goes into fell off and the thread guide fell off it....i can't tell if it is broken or just...
That can be tricky. Some thread guides and needle clamps have to be assembled and then slid up into place with the needle screw holding it together. Some have a set screw to hold it.
Jun 27, 2009 | Bernina Bernette 75
Trhreading
http://cgi.ebay.com/Euro-Pro-Deluxe-Denim-Silk-Sewing-Machine-EP-377_W0QQitemZ8271336746QQcategoryZ3118QQcmdZViewItem#ebayphotohosting If so it threads just like my sewing machine.Draw your thread across the top,down into the first slot,then up and thru the second slot,come down,pass it thru the thread guide on the needle,then thread your needle.Most all machines are basic when it comes to threading.HTH
Kathi
May 20, 2009 | Sewing Machines
Brother XL-5340 Mechanical Sewing Machine Logo
127 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
