Question about Mitsubishi WD-62531 Projection Television
I have a Mitsubishi WD-62531, it is almost three years old and has gone through 5 bulb. Is there something I can do to make this bulb last longer? Is there something that I can check that may be causing it to fail. Reading posts found from a Google search it appears that this bulb only last about a year anyway. Just looking for some help.
  • Mitsubishi Master
  • 17,448 Answers
The biggest enemy of bulbs like that is heat. Make sure the fans are running and are clean. Make sure the fan stays on for a while when the unit is turned off. Other than that there is little you can do without adding a fan or other modifications.
Posted on Oct 29, 2017
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi VS50707
convergence ICs stk392-110 you will need 2 of them.
Posted on Mar 07, 2008
  • 5 Answers
SOURCE: mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Posted on Jun 17, 2008
  • 53 Answers
SOURCE: RED LAMP LIGHT!!
Check to make sure your lamp is not blown.
Make sure you installed a Mits original, and not a generic.
Make sure the lamp is seated and secured properly, as slight movement can cause a loss of connection.
Slide your set out to the side and peer into it through the slats. Can you see the lamp fire on?
Your symptom does not indicate that it could be a problem other than the lamp and the installation thereof, however---there is an instance where 2 capacitors will blow on the power supply and cause a red lamp light to show. Furthermore, the light engine itself could be causing the problems.
But, since you just installed the lamp, I would look over your installation.
Posted on Aug 01, 2009
  • 64 Answers
SOURCE: Mitsubishi WD-52525
The lamps can burn out if you suddenly lose power (and the lamp does not cool via fan). This can cause lamp failures and possibly other failures. Also, if the fan cannot get air sufficiently (from the filter (on the back of the set) this can cause thermal overload and other thermal failures. Be sure all cooling fans (yes fans) are functioning and free of dirt.
SOURCE: I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
Posted on Feb 07, 2010
Mitsu wd 62531 colors are rather dark. Any solutions
check you brightness level , if that does not fix it it sounds as if you may need to replace the bulb, you can get just the bulb or bulb in housing, if you are the least bit handy save the money and just buy the bulb, be sure not to touch the front of the bulb as oils on your skin can damage the new bulb or at the least shorten its life, this is easy to do just fallow the directions in your manual
Jun 15, 2011 | Mitsubishi WD-62531 Projection Television
Does any offer a longer lasting bulb I replace it once a year from Mitsubishi
HI:
The normal usage time for lamps are 6500 hours, thats a little under three years depending on the use of the television, These lamps last longer when they are not turned off and on all the time. The constant heating and cooling prematurely wears out the lamp, also on Mitsubishi lamps have a filter on their lamps that geta cloged with dust from the exaust fan, causing heat to become traped in the lamp compartment which will cause the lamp to blow premautrely, using a compressor try cleaning this filter every 6 months or so for longer llamp life.
May 01, 2011 | Mitsubishi WD-73736 Television
Have a Mitsubishi WD-62327 DLP projection TV. It is a few years old. Would not turn on. Blinks red - 3 short red blinks then 1 longer blinks - and repeats. We have disconnected everything, unplugged,...
if you hold the input and menu button for 5 seconds it will flash you a code 36 is the lamp fan / dmd fan has gone bad. pretty common. not hard to change but will cost 100 in parts and whatever labor may be
Jan 18, 2010 | Mitsubishi WD-62327 62" Rear Projection...
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL MIKEKIMA@HOTMAIL.COM
Dec 24, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Replaced lamp 2 weeks ago. Red light flashing again. Same problem but the lamp is fine. Sound but no picture.
You have either a bad ballast (it powers the lamp) or a bad DMD board. Either one of those will result in a no lamp fire issue. Have a technician look at it...
Oct 17, 2009 | Mitsubishi WD-62531 Projection Television
New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Jan 23, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi tv model wd-62531 less than 2 years old
It sounds to me like your bulb has burned out. Look behind your TV for where the bulb housing is and pull the bulb out to check if it's burned out or not. You'll know when you look at it if it's toast.
Dec 10, 2008 | Mitsubishi WD-62531 Projection Television
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
