2003 Kia Spectra Logo
Posted on Sep 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Check engine light sputters knocks and dies - 2003 Kia Spectra
Trevor Goble
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 123 Answers
  • Posted on Sep 30, 2012
Trevor Goble
Expert
Level 2:
New Friend:
Cheetah:
Answers
123
Questions
Helped
22225
Points
372
There are several issues that can cause this. (1) Fuel Pump which is located on the sending unit in the case tank. (2) debris in the gas tank causing causing the debris to wrap around the boot or the sock (3) clogged catalytic converter (4) misfire of a plug or simply a bad plug (4) speed sensor (TCM) (5) bad air filter
Fuel Pump Assembly from a wreck ($60) plus install or new about $350 installed, cleaning of the gas tank ($90) or new gas tank $300 installed or used gas tank from wrecker ($125), plugs ($90 plus install), TCM speed sensor $250 installed (dealer only) and bad air filter ($20 easy install)
07 Pontiac grand prix 3.8 gt supercharge acceleration sputtering ,no power
knocking noise! ( a cry for help, is ping/detonation boom bad)
never ignore that.!
get the car serviced, is the answer,
yes low fuel pressure on any boosted engines, can crack pistons or far far worse.
the check engine lamp is the warning, ! pre, life or post.
that is its job, called stores DTC< diagnostic trouble codes
and we scan it.
What could cause 2004 Ford Focus to suddenly quit as described below?
Bad connection at battery cable ends, bad alternator. Low voltage can make entire system go dead. Test battery and check all main cable and ground connections. Yes this can happen while driving down the road.
Engine sputters accelerating seems like its missing
Sounds like you need to check your filter's there is one in the tank also.
2005 Sebring sputter and died won't turn on
sounds like an electrical prob. check for corroded battery cables
My 1996 lincoln town car sputters with the check engine light on. First started when the vehicle died at a red light 2 days ago.
check your fuel filter and all your spark plugs and/ or take it to the parts store they will scan your vehicles trouble codes and tell you whats wrong
I have a 1996 dodge caravan 3.0 with about 220,000miles it ran perfect on wed and ran like **** the next day.its spitting and sputtering and if you really get on it the acts like it wants to die knocking...
Sounds like you have a bad bcm as far as the lights ! The running rough and the cel flashing indicates a misfire condition ! Check your plug wires and see if a critter hasnt chewed a wire !
1helpful
2005 chev cobalt sputters at idle. Replaced knock
well i have got quite a few bad parts from autozone they just dnt make them like they used to hahah.....i say take that 1 back nd get another 1 if it still doing this then u can msg me at [email protected]
1helpful
Our 2000 Merc Villager had the engine light on and was making some sputtering noises. It died in the middle of my husband driving it. We went to have it towed the next morning and it started okay so he...
Could be cam sensor, crank sensor, PCM going bad. On these newer vehicles with all the electronics it is hard to pinpoint what it is till the check engine light does come on for it. I would suspect one of the 3 going bad though.
2answers
2answers
Pressure buildup in the gas tank which causes the car to sputter and die unexpectedly.
I have never seen or heard such thing. You have a different problem. Is the "check engine light on?" Gas tanks have pressure in them on regular bases and I have never seen car sputtering because of a pressure in the gas tank.
Top Kia Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Kia Expert? Answer questions, earn points and help others
