Question about Nokia 7250i
Screen on 7250 wont work nd I need the no.s off it nd I hve a mac
The sceen image and backlight are both broken... it is definatly on because I can hear the starting tones and the pad lights up.
I have a mac and so can't use the cable because it is not compatible.
I have a sim to put in the phone but it is no use because I can 't see the screen to transfer the numbers from the phone memory to the sim memory.
I have thought about going to an orange shop but I don't really have time... will use that as a last resort.
  • jasminesalte Dec 26, 2008
    I have just found a solution ... on this link, www.expansys.es/ft.aspx?k=90509 there is someone who has listed the buttons I needed to press in order to switch my numbers onto the sim card :) but thanks for responding
    Problem Solver:
  • 5 Answers
Does your 7250 comes with a CD ? if so then install it to your PC then you can view your files on your PC thru your Nokia PC Suite. Hope it helps.
Posted on Dec 26, 2008
My screen dont light on my aspire 7250
I have just fixed an Aspire 7250 with following symptoms: Only blue Power LED or battery charge LED come on, fan spins, no backlight, no video either on internal screen or VGA output.
Problem solved desolderig BIOS flash chip (W25Q16) and flashing BIOS 1.10 with an universal programmer.
Aug 06, 2012 | Acer Computers & Internet
I was watching a movie and the sceen went black i had audio though.i restarted the computer and now no video black screen. did the video card **** out? video card is a nivia 8600 gt
If you are using a lcd monitor, it is very possible that your monitor backlight failed, have you tried connecting a different monitor to check your video adapter?
If the backlight failed, the image is on the screen, but is not visible unless you shine a light on to the screen
Feb 23, 2011 | Evga nForce 680i SLI (122CKNF68)...
I put a working LCD sceen in a sony S600. He
There is a fuse for the LCD backlight only - if it's blown, you should see something on the display if you look closely as there will be no backlight. If you need help locating the fuse, e-mail me at fotomeistars@gmail.com
Tom
Dec 03, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
My laptop monitor goes out after windows loads.
Sounds like the backlight is broken If it works with an external monitor the backlight needs to be replaced will cost you about 100$ sorry
Nov 13, 2009 | Computers & Internet
The screen suddenly went black while connected to an electrical outlet. Nothing works.
Three immediate possibilities in order of expense:
1) Make sure the brightness is on. Press the F2 key.
2) Screen backlight could be blown out, especially if you can hear the disk seeking, fans, etc. even though the screen is black. Connect your Mac to an external display or TV using the appropriate adapters. If you get an image, you need a new backlight or LCD panel.
3) Entire machine is plotz, especially if you hear absolutely no chimes, disk movement, optical reset, fans, etc. This may indicate a power board or logic board issue.
Sep 30, 2009 | Apple PowerBook G4 Mac Notebook
The screen light
the power button that you use to turn it on, push it, and it adjusts the contrast
Apr 20, 2009 | RIM BlackBerry 7250
MacBook screen dims
first there could be many meanings of dims with a laptop screen one is backlight has turned off and it is difficult to see.  if that is the case use you brightness key to check if it is up, if it is more likely your inverter has gone up and in worse cases the screen. it may also start bright then change dim while loading
there is also the feature on mac to automatically dim the screen a little when unused for a set time.  to change this go to system preferences, go to energy saver, click show details, then move to options, and uncheck the the box that says "Automatically reduce the brightness of the display before display sleep".
i hope this is what you are talking about.
Mar 14, 2009 | Apple MacBook Mac Notebook
I changed my macbook screen, and the backlight now will not work. Everything else works fine, just no light. My real question is what voltage should be coming from the inverter board. I read no AC or DC...
Apple doesn't provide voltage information for the Inverter Board.
If you are getting external video then check to see if there is a dim (un-backlit) image on the display to ensure it is a backlight problem. If so then the chances are good you have a failed inverter board.
Jan 21, 2009 | Apple MacBook Air
Grey white screen and that is all
It looks like you will have to get the backlight replaced/fixed.
May 20, 2008 | Gateway FPD2275W LCD Monitor
Lcd is not working
I'd highly recommend taking into the Apple Genius bar. You've definitely damaged something. You might be lucky and one of the connectors came loose, but most likely you damaged the LCD which will need to be replaced.
Jun 04, 2007 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Nokia 7250i Logo
43 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
