Question about Motorola Mobility RAZR V3
Phone is flashing
My phone keypad is flashing like a heart beat, it's not responding to any keys, when I remove the battery and put it back it keeps on flashing just the same.please help!thanks
    Brigadier General:
  • 7,752 Answers
Your mainboard needs to be reflash so take the phone to a mobile repair center and have that done.
Posted on Dec 26, 2008
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
My message keypad do not respond correctly?
No, you probably got it wet. you gotta do a Chemical cleanup. Totally disassemble the phone, including the internal parts and sink them in ethyl alcohol (you can buy it at a pharmacy) for a day. be generous with the ammount of alcohol because it evaporates (and keep it away from heat sources!) next day, brush it with a soft brush to remove any soil/dirt/rust thet the alcohol loosened up. leave it now to dry, under sunlight or in a warm place for another day. Reassemble it, and Voila! youve a clean as new phone! working in perfect conditions!
I must remark that this method only works with "old" mobiles, since theyre the onlyones sturdy enoght to take REAL beating and keep on working (unlike most touch phones) they got better weldings, better materials, better everything (better price!)
Jul 05, 2012 | Nokia 5800 XpressMusic Smartphone
The phone froze so i put it off and when i tried restarting it it did not come on...ive tried removing the battery and putting it back in butit still will not start.i do not have a memory card...
to solve this
you need to format yor phone
Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. Keep pressed until phone boots up
May 10, 2010 | Nokia E63 Cell Phone
My phone n79 key pod are not working?
I m having the same problem with mine... I took the battery out and put the phone in the freezer over night thinking it would remove some moisture... don't know if it did anything but today it works. Thinking about replacing it with a 5800 if it does not work.
Apr 01, 2010 | Nokia N79 Cellular Phone
Buttons not working
The volume key is stuck that's why the volume bar keeps on popping out. It is also the reason why the keypad is not working. You have to unstuck the volume key to check if the keypad really doesn't work.
  1. Remove the battery cover and battery.
  2. Remove the camera cover by prying the locks along its sides and lifting it up to expose the volume keys.
  3. Insert a needle between the volume key membranes and the board to unstuck it. The membranes should click when pressed.
  4. Install the camera cover in reverse order.
Inform me if the volume keys work fine but the keypad buttons don't.
Jan 01, 2010 | Nokia 5310 Cellular Phone
E71 not all keys responding
It could be dust that creeps into the keypad. A very common prob. Solution is to get it cleaned. Try it yourself with a hair dryer. Just keep the heat off. If that does not work then go to Nokia Care.
Jul 04, 2009 | Nokia E71 Smartphone
The keypad do not work
Either a software re flash may help or a keypad replacement. Usually facial moisture could be a cause of this. i would recommend trying a blow dryer on the keypad for 40 seconds with out the battery to see if that fixes the problem
Apr 06, 2009 | Motorola Mobility W490 Cellular Phone
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Aug 02, 2008 | Polar F6 Wrist Watch
Motorola v3 razor
try by replacing the battery aand the sim on to another mobile phone and try
Jul 13, 2008 | Motorola Mobility RAZR V3
Flashing on and off
well that and unlocking the phone voids your warranty. First try taking your battery out and then holding down the # and * keys while you put the battery back in. If it didn't automatically load to a black screen displaying your software version, power it on while holding down those keys. once you've reached this screen let go of the keys and power it on normally. If that doesn't work reply to this post and I will troubleshoot further.
May 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
82 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
