Question about Uniden DCT646-2 Cordless Phone
Rotary dailing My phone just out of the blue started rotary dailing. How do I reset this to digital? Can't find a switch or something to change back.
Switch rotary phone to touch tone
Enter the model of your VTech DECT 6.0 phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
May 25, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
Change pulse tone rotary
To change between pulse and rotary, from an administrator handset press MENU-9-1.
Jun 26, 2013 | EnGenius DURAFON1X DuraFon 1X System Phone
How do you reset the phone system... it sound like a rotary dial when Im calling out
If it's rotary then your system was reset already.
When a system defaults it will assign 2 lines to all phones and give Jan 1 as the date.
Change from Rotary to Touch tone is done under Config/Lines/Data
If unsure who to program or navigate or config password then call in a vendor/tech.
Sep 24, 2012 | NorStar Meridian M7310 Phone
Ingersoll rand intellisys 22128763 stays on 'checking machine' after a power outage. How do I get it back to 'ready to start'?
e stop warning on screen stays on. i checked with a meter and both sets of contacts work. left side with red wires have 130v ac in and out of switch. right side of e stop has blue wires and no voltage. i ohmed with meter and switch is working
Feb 28, 2012 | Ingersoll Rand Tools & Hardware - Others
How do I reset my e250i?I get enter password after dailing *2726*3855# ,please help.
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone.
Enter *2767*3855# from the standby screen. (You may need to remove the SIM before it will allow you to type the code in)
Jan 03, 2011 | Cell Phones
No sound coming from my blurparrott b250-xt, but it's paired to my jblackberry 9700 no voice dail was working fine.
"no voice dial was working fine."
I cant understand this line.What are you trying to say please be explain more.
Have you tried to reset the device?Just try and let me know.
1 switch phone on and pair with headset.
2 when paired (blue light flashing) put the charger on the headset for exactly 10 seconds.
3 Remove the charger.
4 The lights alternates between red and blue(Resetting)
5 When light stops, it is resetted.
If still the problem persist it is hardware problem so let me know so i can help you more.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 27, 2010 | VXI Corporation Blueparrott B250-XT...
Continuous dial tone on phone line . When i try to dial out- i just get a continuos dial tone- happening on my 2 cordless, landline is fine. Dont use a magic jack, changed out hardware, new cordless dont...
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Aug 31, 2009 | Panasonic Lands Phones
Timer quits shutting the lights off and time flashes 12:00AM
Intermatic is a reliable mfg. if you have a it wired to directly to a light and only a light, you most likely have a defective timer. Bring it back and purchase a rotary timer with on-off switch. more reliable. I too installed the same type of timer and went through 3 before installing intermatics rotary timer/switch.
Jan 24, 2009 | Intermatic Inc. ST01C Digital In-Wall...
Need to reset my mobile password back to default - cannot remember what I changed it too
ou can enter the hard reset code but that will delete everythi8ng on the phone the code is *2767*3855# i haven't been able to find the password reset for the F480
Jul 28, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
TC1200 TONES/PULSES
There is usually a switch to change it from dial pulse to touch tone.If there is no switch check your user manual to see if there is a screen option.
tk46
Jun 19, 2008 | Panasonic KX-TG1033S Cordless Phone
Uniden DCT646-2 Cordless Phone Logo
21 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
