Question about Hotpoint 24 in. BF72 Built-in Dishwasher
New Integral Hotpoint dishwasher LFT04
How do we fix our 2 part (drawer and door) fascia to the front of the diswasher using screws? We think we can do door but not drawer front.
Thank you.
We finally worked out what all the separate parts were for!! The instructions given were hopeless! Would be pleased to help anyone who encounters the same problem.
Posted on Dec 27, 2008
My hotpoint diswasher is showing F as a fault in the door
can you send more information please like make model brand serial number
Sep 02, 2014 | Hotpoint 24 in. BF72 Built-in Dishwasher
I cant get the back off hotpoint aquarius wma56 to change bearings
the back does not come off but the front does.
remove top lid ( two hex head screws on side of lid, under plastic covers)
take out dispenser drawer. reveils 3 screws
remove screws and slid front panel to the right (reveils 2 scrwes left and right)*
remove bottom kick strip ( reveils 2 more screws)*
undo door seal retainer, and remove 2 screws holding on door lock.
now remove 4 screws holding on front panel.*
panel now lifts up and off.
Jun 25, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Apr 21, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Two Black panels on bottom of diswasher removed
Try www.applianceart.com - I think thats the panels you are referring to? Otherwise, the manufacturer will be able to help you for a steep price.
Jun 21, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Can bearings be removed without removing the drum itself on a wma54
sorry no its a big job but here goes isolate from electric and power remove lid and rear bottom cover.
remove soap drawer and remove screws you can see behind it then remove fascia, then undo the door seal and plinth cover ,then remove front panel.
then remove dispensor hose from tub, go to the back remove sump hose and motor and wiring to element then remove top front sub frame and undo the top and bottom weights then remove the pins that hold the suspension legs to the tub lift off the springs and the tub is free.
Then split the tub knock out the old replace with new that is assuming you dont damage the shaft of the drum support whilst removing il then do it all in reverse this normally takes me 2 hours it might take you 2 days but hey lifes full of challenges good luck
Sep 28, 2009 | Hotpoint WMA54 Front Load Washer
Kitchenaid Dish Drawer unit is canted forward; I need to get to the back legs to adjust them downward. How do I get to them?
Open the dishwasher door and undo the two screws that secure the face to the counter-top. Open the kickplate and slide the diswasher out of it's hole. You should be able to easily access the back legs now. It may be easier to disconnect the drain and supply hoses (turn off the angle stop first) and flip the dishwasher upside down using a carpenter's level to make sure all your feet line up. Flip it over, reconnect, and reinstall.
Jul 01, 2009 | KitchenAid Dishwashers
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Door lock assembly Hotpoint dishwasher
Hello.
First switch off the power.
Get the cabinet door off, start by removing the side screws that hold the door (please have someone to help you, holding the door, because this doors are heavy.)
After you removed the door, remove the screws holding the fascia (about 2 on each side + 2 holding the door lock).
Remove the fascia and you wil get acess to the door lock, disconnect the wiring from the micro switch, connect the new par and reverse the process.
Cheers
Aug 27, 2008 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Problem with hotpoint aquarius fdw60 diswasher
My mother has a neighbour who has a new hotpoint dishwasher which caught fire inside (Plastic on door front melted!).
Please contact Hotpoint - if yours is new, check to see if they can replace immediately otherwise its worth booking the engineer to sort £90 - free parts on machines less than 5 years old.
Jan 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. BF72 Built-in Dishwasher Logo
356 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
